Good luck with the truck, looks awesome
Share this post
Link to post
Very nice truck.  Glad to know it has a good home. There was an article in Double Clutch magazine about the Kreitz company a few years ago. I believe there may have been pictures of your truck in that story.
Share this post
Link to post
nice lookin ride.....5x4s take a lotta practice thiers 2 gears you need to skip in full shift sequence   cant remember wich 2.off hand....but as you go along especially when empty you will find out you can skip quite a few,,,,no lugging is mainly important when your heavy and gearing up.such as long pulling grade dont do it......rottella is perfect or delo 400....reduction switch generally turns off steer brakes......engine brakes   depending on grade and weight usually dont hold well in high gears.....usually 3rd range is around the spot....yes turn on top of hill turn off bottom of hill real important.....magor engine damage if you forget  and release clutch at an idle....good luck hope this helps you ....have a ball with it.....bob
Share this post
Link to post
napa is a good place for filters they have alotta crossover books....bob
Share this post
Link to post
Nice truck.  My father saw this on the road on Saturday.    I think I have a picture of this truck that my father took in the late 70's.  I have a IH Fleetstar that belonged to your company.  I don't have any answers to your questions.  Good luck with it.  Mike.
Share this post
Link to post
That is such a cool truck with a great story. It looks like you have the perfect use for it. Enjoy.
Share this post
Link to post
Very nice truck, I believe the dry/slippery switch either limits or stops the air going to the front breaks when it's in slippery mode.
Share this post
Link to post
Nice ride and welcome aboard. You have come to the right place for any help you might need.
Every lubricant guru I have heard speak or read an article from seems to think that the 15-40 Rotella is the best oil to use in older rigs. However, the formula recently changed to comply with new emissions and mileage requirements, so I'm not sure the new blend is still recommended.
The "Dry-Wet" switch does limit the front brakes and I strongly urge you to disconnect it as it severely reduces the braking capacity of the truck. The use of it is especially thrilling in a fire truck when approaching a controlled intersection while feeling like you are gaining speed instead of stopping while applying the brakes.
Please try to bring the rig, with the roller on it, to the Macungie show next June. Great show and your rig would be a sure hit,
Share this post
Link to post
Nice unit.  Should do well in your application.  The only thing I would have done differently is to keep the LED lighting.  They solve 95% of the problems people have with trailers.  I would have spent a few hours reversing the ground/power leads at each light.  From 1935 to 1977, my dad had a small local truck company.  I worked there as a teenager, and most trailer problems involved keeping those darn incandescent lights working.
Share this post
Link to post
The dry/slippery switch cuts the air in half on the steering axle! Some three axle tractors I drove in the 70s had no brakes at all on the steering, presumably to avoid a steering tire or tires locking up on slippery roads and causing you to lose steering control! At some point this "feature" was no longer offered thank goodness!
Share this post
Link to post
I'm really glad to see you taking care of a truck that belonged to your dad's company...it's a good thing to keep your heritage going.
Share this post
Link to post
Here are some filter numbers as I have a beast like yours but without the winch and exhaust brake.
Engine oil  - Wix 51233
Primary fuel - Wix 33405
Secondary fuel - Wix 33218
Think there is a filter in the power steering pump but I don't have that number. Good luck with the old gal and be gentle with it!
Share this post
Link to post
Thank you all for the wishes and the solid info you gave me.  Thank you Fuzzy Buzzard for those numbers, that makes it super easy.  The next trip I make will be this week to take the steamer to Hay Creek festival.  I will have the truck and roller at the show all weekend.
Thanks again!
Share this post
Link to post
I saw that Hay Creek is having ab antique auto/machinery section but I will not be able to make it. Hopefully you can bring it to Mack Day in Lititz on Oct 7.
Here is the Fleetstar I mentioned.   Not a Mack and not too nice but I still like it.  Mike
Share this post
Link to post
those were always one of my favorites as a young guy i remember alot of them especially doing city deliverys...thanks for posting...bob
Share this post
Link to post
Last one like that I was around had a DV550 in it, not a good engine!    terry
Share this post
Link to post
This has a 549 V8 gas and a big top loader rear.  Definitely used for heavy hauling.  I would like to fix it up but it is low on my project list.  Mike.
Share this post
Link to post
there used to be a lot of them intercrashionals here on the east coast with green leakers in them.
especially 6-71's. you could hear them coming from 1/2 mile away
Share this post
Link to post
I think the DV 550 was a converted 549.   terry
Share this post
Link to post
That could be a pretty truck! The mirrors and turn signals are nice, but I'd like to see one with the bullet chrome cab markers!
Share this post
Link to post
A friend  of  mine  bought   (and has since sold) one of  the  R models  Kreitz had. Doug Maney  found it for him.  Very straight  and original  before  he put a new dress on it. Al  post-510-0-09340000-1360418162_thumb.jpg.f279a48b9c62b79c740dbb9e062a3dc9.jpgpost-510-0-38731800-1360417703_thumb.jpg.8f052242237b16547bd4859d8587b86d.jpg
Share this post
Link to post
I took my son to the Hay Creek Festival.  It had nothing to do with this truck being there.  It is pretty nice.  It was nice to meet Jarrad.  Mike
Share this post
Link to post
Where are you located out of.
Share this post
Link to post
A B model with a V8 which is still being used, how rare is that?  I'm happy that you are as committed to it as you seem to be.  The quad will get easier with time, trust me.  And if you like hot, loud trucks that smell like oil I'd say you've got the right stuff.  Best of luck with it, and don't forget to keep us posted.
Share this post
Link to post
    No registered users viewing this page.
Important Information
We have placed cookies on your device to help customize your user experience here on BMT. You can adjust your cookie settings to your preferences if you like, otherwise we'll assume that you're okay to continue.
