autocardc
New Autocar Conventional Truck
20 minutes ago, Maxidyne said:
Maybe... But most of these trucks will be bought by fleets, not owner operators looking to impress the other drivers at the truck stop. Even vocational fleets are looking for better aerodynamics and sloping hoods are good for visibility too. At least they gave it a chrome grill so it don't look like a Mack!
WellI would agree with James J.  It's a vocational truck!  You can still have  a sloping hood with decent visibility but square it off!  No need for an A -car to look like Snoopy.
Then again in terms of visibility, the manufacturers spend a lot of money to  provide that, and then the a-holes spend all kinds of money for drop  down visors and they  drive with the seat on the floor.  You see one coming at you and think.."oh autonomous truck-don't see a driver i that thing🤪
Share this post
Link to post
Agreed, but most of the clowns that drop the seat and hide behind a drop down visor can't get financing for a new truck anyways, so they'll have to wait for these Autocars to hit the used truck lots before they get a chance to pimp 'em out.
Share this post
Link to post
We did it again. Autocar is launching two truck models: the Autocar DC-64M, for concrete mixers, and the DC-64P for concrete pump applications.
Click here for all the details: https://zcu.io/DoVc 👷🇺🇸
#AutocarDC #AutocarConcreteMixers #AutocarConcretePumps #AlwaysUp
Share this post
Link to post
Autocar Launches Two Construction Truck Models
Heavy Duty Trucking (HDT)  /  October 3, 2019
Autocar Trucks has launched two tuck models designed for the concrete and construction industry.
The Autocar DC-64M is designed for concrete mixers and the DC-64P is made for concrete pump applications. The Autocar DC is a conventional truck engineered from the ground-up for severe-duty vocational applications.
“The new DC models are the result of extensive input we received from our advisory board of concrete professionals,” said Eric Schwartz, managing director of Autocar Trucks. “Every inch of these trucks has been reviewed and improved based on the decades of experience of people operating concrete mixer and boom pump trucks.”
The Autocar DC-64M and DC-64P bring several innovations that make them uniquely suited for their respective vocations, according to Autocar.
The Autocar DC’s cab was designed by Autocar for exceptional productivity, durability and safety in the concrete industry. The cab structure is built from a combination of steel, aluminum components and corner castings, to withstand years of abuse the concrete industry dishes out.
The workspace of the cab maximizes productivity for drivers with everything designed to be visible and within easy reach, while the wide, raked windshield provides better visibility for safety. The interior uses materials like polished aluminum bars for door pulls and steel sheets as dash panels along with a full steel structure inside the dashboard.
The Autocar DC-64M and DC-64P join the other DC models featuring ultra-high-strength 160,000 p.s.i. steel frame rails, which Autocar says are stronger and lighter than the rails on comparable trucks and eliminate the need for frame liners in nearly all mixer applications.
“We’ve routed air lines and self-cleaning electrical harnesses on separate sides of the frame rail to make service easier,” said Tom Harris, Autocar’s vice president for concrete mixer trucks. “But even more importantly, everything is mounted away from the frame rail channels where concrete and liquids accumulate, so that will avoid additional problems we’ve all had to deal with before.”
The DC also features Autocar’s new Always Up display, with prominent warnings and dynamic gauges that tell the operator or technician what fault has occurred and shows them how to fix it.
“The DC-64M incorporates a raft of improvements and features specific to concrete mixer trucks, such as rear-engine PTOs and asymmetrical self-leveling front suspensions,” said Schwartz. “Every DC-64P will be custom-engineered for the specific pump body the pumper selects. So suspensions and multiple steer, drive, and auxiliary axles will all be selected and placed for optimal weight distribution and Autocar’s industry-leading maneuverability.”
The Autocar DC powertrain initially includes Cummins X12 engines up to 500 hp and 1,700 lb.-ft. of torque, with additional engines and specs available in the future. Transmissions include the Allison RDS4500 and 4700 series for maximum torque at low speeds and easy drivability on the road and in construction sites.
The company has already accepted orders for production of the DC models at its Birmingham, Alabama factory, for delivery in the spring of 2020.
Share this post
Link to post
KS: For a while I thought you worked for Paccar after Mack. Then you popped up in Aussie land as a Scania man. Now you sound like an A-car man. Not a bad choice no matter what. Looks like the sky is the limit for A-car. Now only if we can keep those greedy foreign fingers out of the A-car pie.
Share this post
Link to post
Looks like it would make a good heavy wrecker!
Share this post
Link to post
I was thinking , yes  dangerous I know
Do rubbish trucks have dual control in the U.S.
If so do these trucks with dual control ? As in a steering wheel on each side
Would make it easier to make it RHD
Just a thought
Paul
Share this post
Link to post
Just a thought
Paul
Yes
Very common on residential automated side loading trucks
Share this post
Link to post
The movie Hoffa featured an old Cabover similar to that Autocar or a Sterling,and a bunch of 361 and similar Brockways.
Share this post
Link to post
I wonder why they are not promoting it for dump truck applications yet?
I don't know how the X12 performs in real world, I have not driven one, but I have pulled 140,000 pounds up and down our endless 8 to 12% hills for years with E6 350 Mack's and 1650 torque Detroit's. So a 1700 ft-lb X12 should do it too.
Share this post
Link to post
I have pulled many 121.000 k gross loads with a 220& an r96 roadranger back in the good old days when the limit was 73.280
Share this post
Link to post
