Mack v8's before the E9
james j neiweem
Now I say this whlie owning a E9, but I've never been a big fan of V8 diesels.
More times than not, they will have a shorter stroke due to the Vee design. Shorter stroke means less torque.
They are also usually harder to work on because they have more parts and the whole thing is usually stuffed in a tighter package.
V8s are fine for your 350 chevys but when it comes to heavy duty diesels, I want a in-line.
I'm not a big specialist as everybody knows and laugh but making repairs on any V8 engine requires more efforts than on in-line one.
Vlad, we feel the individual cylinder head design of our V-8 makes it far easier, faster and cheaper to service. And, the current V-8 shares many common parts with our in-line engine.
Am I to understand you work for Scania? :whistling:
I know unrelated to post title , when i was running my E9 on the road and it was tuned right (with all stock parts)only truck that even came close to keeping up with me on a hill was a 600 cat .
I never came across any KT trucks that i know of. I know that now that you can make the others run with it that is if you want to do head gaskets every 100,000 or so.
Never worked on the older 8s and very little on Mack Inlines, Sooner work on E9 then a cat any day.
Grant Haulage was given a demo with a 1000 series Mack V8 (pre E9) in an RWS in the early 80's. They ended up accepting the demo unit as there own on the condition it was repowered with an 8V92 Detroit. They were unimpressed with the pre E9 engine and never spec'ed a V8 Mack in any of there trucks considering they rarely ever hauled less then GVWR's of 100,000lbs. The E6 350 did just fine for them hauling 110-120 gross.
Interesting fact that KamAZ engine was bulid originally with 8 separate heads.
This desing is still in production with some modifications such as turbos and electronics.
Being learned of American truck history I was surprized V8 engines were not everywhere since the most of Russian trucks starting from 60's were V8's.
Keeping in mind KamAZ has his roots from Mack it's surprize the engine style is completely different.
I liked my Ford PSD because it sounded like a baby E9.
There are lots of V8 motors making plenty of power. Personally I think it was all in the packaging and weight of the V8 compared to I6 motor. In trucking, weight is everything and if you can do the job with a lighter motor, then so be it. Bigger is always better, but sometimes it is just not practical. If everyone wanted one, they'd still be making them here.
What is the weight difference between an E9 and the I6?
2 words usually kill the argument between I6 and V8 engines.
Volumetric Efficiency.
I'm only referring to Factory builds not engines blown ou of proportion with add ons and programs that cut th mean engine life in half but will kill in the 1/4 mile.
anyone know what the torque rating was on early V8s they always say its not the horsepower its the torque
864 V-8 639 to 740 pounds of torque
865 V-8 322 h.p. 1100 pounds torque @ 1350 rpm
865C V-8 317 h.p. 1211 pounds torque @ 1350 rpm
Getting back to the topic, major problems. with the old Mack v8's.
864 injector pump, junk!
Cracking heads, bad design with injector nozzle about 1/4 inch from the valve seats. They even had an expansion joint machined in to prevent the cracking. dropping valve seats and valves.
Blowing head gaskets, They need constant re-torquing.
Coolant leaking around head bolts. Freezing and hoping the head off bolt.
Main bearings, need to roll in a new set about every 150K miles. Smaller than the E9 main bearings.
Don't have them against the governor up a hill and let off going down the other side. Valve seats cool down and fall out if heat goes out of head to quickly.
Needed more maintenance than and I6.
Was a one driver engine. Don't give one to the new kid... rods out the side.. Needed warmed up good before putting a load on it.
Weight, about 600 lbs more than I6.
The E7 was one of the best Mack engines in al around good power, low maintenance, and durability. Don't get me wrong I love these V8's but they are not at there best most of the time for many reasons. Nothin sounds like one... Only thing as good sounding is a Supercharged 275 Cummins at full tilt...
I was looking at a '75 RL700L with a factory two stick 12 speed in it.... it also has a V8.... badge on it calls it a Maxidyne.... shouldn't it be a Thermodyne?
Maxidyne 865 325HP 5 or 6 speed Gold color
Thermodyne 866 375HP 12 or more speed Silver color
Thermodyne 864 255-310HP Triplex or Quad Green/gray color
E9 is 2800 Cat 3406 is 3000 dont know about Mack Inline
