It varies greatly from truck to truck depending on the load weight hauled and terrain operated on.
You are listing a B 67 as your truck.. Bob-tailing to shows I would hazard a guess of 10 to  12 MPG????
In ANY situation your fuel mileage will depend a lot on how heavy your right toe is!!!!!  Be EASY AND GENTLE!!!!
  • Thanks 1
Brocky
I know your asking about a B model but I found this in an article about the Mh cabover
7.7 Is great by todays standards, but in an 80s cabover it is incredible! A pyrometer is a big help when learning how to drive efficiently if your truck has one.
Probably doesn’t answer(YOUR) question , but I thought I’d throw this out there my Peterbilt with triple trailers flat ground it gets between six and seven pull a hill it goes right down to 2.6 ha ha at least that’s what the dashboard says
if you’re looking for an average on the job, it’s usually between five and six… like these guys said, and all the depends on what you’re doing with it pretty much. Bob
320 coolpower, even pulling a road train at max load it is never worse tuan 4.5 MPG
Running along empty with the float on is 7 plus, single trailer fully loaded is 6 - 6.5 MPG
Speed and wind resistance are the killers, no faster than 60 MPH for good economy, thats why in the fuel crisis days of the 70s the limit in the U.S. was 55 MPH I believe and a little bit slower here
Paul
glad it's posted as a "fun question" ! no offence can't see an acuate answer without more specifics.  same as a question of "how drunk can I get with only half bottle of bourbon ?? 😱😂
  • Haha 1
I dunno if the same research was done in the fuel crisis of the 70's in the U.S. as was done in Australia
But with out a doubt the single biggest factor for fuel economy was speed
There were graphs and charts and all types of things
To go from 55 - 65 took nearly twice the power just to overcome wind resistance
So I wonder just how fuel efficient trucks of today would be driven at 55
50 - 55 was little change
Under 50 wind resistance made little difference
Personally I find it much easier on me to drive a little slower, a lot more time to react to things and Im not on edge watching the speed and the cops and well trying to pass people all the time
And I always see the same vehicle's along the road that broke sound barrier passing me
Paul
7 hours ago, JoeH said:
+1 on 55 mph. If you've ever ridden a motorcycle on the highway then you know this first hand. Wind resistance on your body is negligible up to 55 mph, start getting above that and your arms start getting a workout to keep you in the saddle.
I used to ride. We had to stay overnight halfway through day. The wind was blowing too hard going from San Diego to Reno.
