Just to complicate things sometimes S stands for single reduction rear.   I’ve seen it in fire trucks but might have been used in other models.
But with B’s and R’s before the long vin the S was for six wheels. There has to be a table somewhere with all this in it.
Edited by Truckcrazy
On 6/1/2025 at 7:53 PM, mechohaulic said:
S would be a 6 wheel truck- count wheels not tires .  4 wheels on rear and 2 on steer. 4+2 == 6. the  T in vin would be single axle. while at Mack Blakeslee prestress ordered a fleet of huge heavy DM's . combo of single axles and tandems; the single axles having frame rails ft higher than most were DM611   ?? - all had quads. now I confused myself and contradicted earlier post , they were very heavy triple framed with 100 ton osculating 5th wheels (which I installed everyone ) having 4 in spacer blocks under 5th wheel plates. all 3/4 hand drilled bolts. they may have been DM611  T's
single axle DM's  would be DM611X. looked at one today at truck show in Bethlehem CT specifically to see model . NOT  DM === T's.
On 6/1/2025 at 5:05 PM, mechohaulic said:
no such thing as "I haven't done anything ":you were pacing yourself during extreme conditions building energy to give it heck later .!!
im supposed to be pulling my wifes vacuum cleaner apart after GYM,,,i might have to bring a fan out there,,,it has been very hot here lately,,but im not complaining,,,ohhhh no were stepping all over hicrops tread sorry,,,lol.bob
  • Haha 1
  • 1 month later...
4 minutes ago, hicrop10 said:
Found some pin holes in my one fuel tank,has anyone used JB weld on pin holes? If not what have you used?
not jb, but we used to use the epoxy stick bade for fuel leaks.
dont remember who made it, but i want to say 3M
To fix my leaks I used a MIG welder. My tank had a bunch of tiny leaks under the tank straps.  Of course the tank was off the truck and empty.  I ran compressed air through the tank for a few minutes first. None of the small short welds made enough heat to do any harm. I kept putting air to into the tank after each spot was welded and eventually I found all of the pinholes and welded them up.
I leave the air flowing into the tank why I weld the holes
Never had a issue, diesel is more dangerous than petrol as the metal absorbs the diesel and it sort of evaporates off as it is welded, can be seen while welding quite easily
Once petrol is evaporated it is gone, just something to remember when welding diesel tanks
Paul
I patched up my B tanks a few times.  Drained it down and tipped it up so fuel was away from step area that needed patched.  Ran a piece of 16 ga and welded it solid.  Didn't blow myself up.  Diesel fumes area as explosive as gas.
I finally gave up patching and ordered new aluminum tanks.  Didn't I see Watts offering new steel tanks?  Very pricey.
  • 2 months later...
  • 4 weeks later...
I might have missed it but what was your final fix on the fuel tank leak, the one on the LJ was so bad I had to cut the complete bottom out, have a piece rolled and weld back, every Superliner I’ve had has had a leak on the aluminum tank, water pitts that cavity,, I’ve took them off and patched them too many times! The next time I remove a tank on a Superliner I’m cutting that a” Sump “ completely off and weld a piece of aluminum over the hole.
I used a mug weld.I’m thinking of using a tank sealer, just have to makeup a net to hold tank to splash the cleaner and sealer around the tank.
