PeterMack Posted April 8, 2017 Share Posted April 8, 2017 I replaced all my power steering hoses, and cleaned out the reservoir on my 64. The fluid was red when I dumped it out. I've heard of guys running atf for power steering fluid. Can this be done on this truck or is there something more specific that I should be looking for? Quote Link to comment Share on other sites More sharing options...
Brian Blaylock Posted April 8, 2017 Share Posted April 8, 2017 You should not have any problem with atf or power steering fluid either one 1 Quote Link to comment Share on other sites More sharing options...
Hobert62 Posted April 9, 2017 Share Posted April 9, 2017 I read somewhere it really dosent make much diffrence what types of oils used in old equipment. Today's oils have much better characteristics of oils when this stuff was designed. 1 Quote Link to comment Share on other sites More sharing options...
Quickfarms Posted April 9, 2017 Share Posted April 9, 2017 Viscosity is more important.Some cars run atf in the power steering I have a tractor that runs motor oil in the hydraulic system 1 Quote Link to comment Share on other sites More sharing options...
PeterMack Posted April 12, 2017 Author Share Posted April 12, 2017 Thanks. I will try some atf and see where it gets me. Quote Link to comment Share on other sites More sharing options...
Underdog Posted April 12, 2017 Share Posted April 12, 2017 Most Mack's I have seen use the same oil that is in the crankcase. This was done to prevent cross contamination, I believe.Sent from my XT1254 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Maddog13407 Posted April 12, 2017 Share Posted April 12, 2017 yup,most b models I have seen with ps ran 15 40 Quote Link to comment Share on other sites More sharing options...
Mike Posted April 12, 2017 Share Posted April 12, 2017 Automatic Transmission Fluid is the best light oil since it has been extremely refined. I've used it in the crankcase to clean parts. It can be used while running to clean noisy valve lifters. Quote Link to comment Share on other sites More sharing options...
41chevy Posted April 12, 2017 Share Posted April 12, 2017 My B and R both use the same oil as in the crankcase. Remember ATF has additives to induce friction so the clutch packs and bands work on an automatic Kind of a no no one a P.S. system.You really feel the need to be specific, run Power Steering oil in it Quote "OPERTUNITY IS MISSED BY MOST PEOPLE BECAUSE IT IS DRESSED IN OVERALLS AND LOOKS LIKE WORK" Thomas Edison “Life’s journey is not to arrive at the grave safely, in a well preserved body, but rather to skid in sideways, totally worn out, shouting ‘Holy shit, what a ride!’” P.T.CHESHIRE Link to comment Share on other sites More sharing options...
Popular Post j hancock Posted April 12, 2017 Popular Post Share Posted April 12, 2017 Is the power steering system the old B style with the pump off the back off the generator? I looked at a Mack B operation manual and it list for hydraulic P/S to use Type "A" Suffix "A" automatic transmission fluid. I agree that there is probably way more friction additive in the ATF now than there was in ATF 53 years ago. On later rigs with the PS steering pump on the back of the compressor, it runs engine oil. Another vote for P/S fluid if it is the early stand alone set up. 4 Quote JimIt doesn't cost anything to pay attention. Link to comment Share on other sites More sharing options...
41chevy Posted April 12, 2017 Share Posted April 12, 2017 (edited) 4 hours ago, j hancock said: Is the power steering system the old B style with the pump off the back off the generator? I looked at a Mack B operation manual and it list for hydraulic P/S to use Type "A" Suffix "A" automatic transmission fluid. I agree that there is probably way more friction additive in the ATF now than there was in ATF 53 years ago. On later rigs with the PS steering pump on the back of the compressor, it runs engine oil. Another vote for P/S fluid if it is the early stand alone set up. Type A was pre Dexron.. I've never seen plain Type A any more. Go to Napa and look for "Type FA" fluid. It comes in a black bottle with a black cap. . Type F and A , are so similar they are basically the same, just like Dexron/Mercon. Hence the "Type FA." Edited April 12, 2017 by 41chevy 1 Quote "OPERTUNITY IS MISSED BY MOST PEOPLE BECAUSE IT IS DRESSED IN OVERALLS AND LOOKS LIKE WORK" Thomas Edison “Life’s journey is not to arrive at the grave safely, in a well preserved body, but rather to skid in sideways, totally worn out, shouting ‘Holy shit, what a ride!’” P.T.CHESHIRE Link to comment Share on other sites More sharing options...
Maddog13407 Posted April 13, 2017 Share Posted April 13, 2017 I put a power steering system om my B when I first put it together with the pump off the back of the ac compressor. the scrap truck I took it off had atf in it and the belts were loose. when I put it on mine and put atf in it it was all over the road like an olf Ford with a twin I beam front end. ended up takin the Shepard box out and putting the regular arm strong back in. probably should have flushed the system and tries some 15 40. doesn't really steer that bad with the 522 front axle but I have jockeyed a few trailers around with it that will make you curse. Quote Link to comment Share on other sites More sharing options...
PeterMack Posted April 14, 2017 Author Share Posted April 14, 2017 Mine has the pump on the back side of the generator. Quote Link to comment Share on other sites More sharing options...
HarryS Posted April 14, 2017 Share Posted April 14, 2017 I have a Garrison unit that runs off of the generator also. The manual says to use motor oil of varying viscosity depending on the temp. When I had the steering assist cylinder rebuilt last fall I asked about which fluid. The shop guy said it didn't matter which between ATF, hydraulic oil, PS fluid or motor oil as long as it is non foaming. I use 15/40 Rotella which seems to work fine once all the air is purged. 1 Quote Link to comment Share on other sites More sharing options...
