Here are a few questions to run by you:
Currently all my trucks are tagged with antique plates as they are cheap and let me run around Illinois without limitations for my purpose. I'm thinking of licensing my 80 R model with regular plates to 45,000lb rating so I can use the truck. If I baseplate in Illinois, and stay in Illinois, no problem and won't even need a log book.
Let's for sake of conversation say I want to go to New Mexico from Illinois to pick up a restoration candidate that is owned by me. On this retrieval mission, what do I need to do to be legal, and who do you get trip permits from? In my car hauling days I baseplated in Illinois, and purchased apportionments for Indiana, and Missouri but never ran out of those three states. This was contract hauling from point "A" to point "B" dedicated and nothing else.
I no longer have dot numbers so I'm starting from scratch.
Thanks,
JJ Keller does fuel permits for other states along with any other permit you need.
Is that like "Transceiver" used to be?
So, from a permitting point of view, does it matter if you are doing this for yourself as opposed to doing it for someone else? If you are picking up a truck you bought, do you still need permits and log books?
By the rules most anything over 10,001 pounds is consider commercial. What I am wanting to do is private carrier rated as it supports another business that is not transportation for hire.
J.J. Keller has quite the website and is helpful. I've emailed some questions and my stated purposes so should get a response shortly.
......more like if you can convince Barney Fife on the side of the road that you AREN'T commercial. Looks like a duck, talks like a duck............they say it's a duck no matter what you think or show them otherwise.
Here in VA weight has no bearing on your commercial/non-commercial classification. It is strictly if you are using the vehicle for commercial use or not. I can plate my MH for non-commercail use and haul 60K if i wish (never will) without being commercial and do NOT need a CDL. Being commercial or not is a large and costly factor.
Fred
I don't know, but whatever you find out is going to be very useful for me, Uncle Rob.
Ben
I need to have at least one heavy truck I can work with so I'm seriously looking to do this. I know some laws very from state to state so I'll prolly only get generic information but will post what I find out.
Uncle Rob
Could you have a repair/work order written up for the vechicle recovery? I used a buddy of mine's PA towing/repair plate to get my Cruiseliner back from the state of Indiana. He gave me the plate with a work order saying it's pickup and destination being his shop for repair.
Just add the word "FARM" to the side of the truck door with old house paint, hang baling wire on several stake pockets, wear Key Imperial striped overalls that are 4 inches too short, tuck any long hair up into a straw hat with holes in it, roll around in manure before you start out, chew on a piece of timothy hay, and practice a sort of "hang dog" blank expression on your face.
If the flat hat DOT boys ask you what kind of farm you have, just be honest and tell them it is ROB'S FUNNY FARM, start jumping up and down and belt out your version of Johnny Cash singing: "I'm hauling livestock........"
Then you won't need no stinkin' permits to get to where they take you.
Oh, and don't wear some sissy sandals or crocs on your feet, you have to have LEATHER BOOTS or go barefoot. Just because Jesus worn open toed shoes does not mean you need to do the same. Those DOT boys know a fake farmer when they see it.
Rob even though I have been out of the loop for a while in the past you could get your Il. Base plate and fuel sticker and then get a temp. IRP and IFTA permit from each state you are going to run in you can register as either for hire or private carrier the best place to get these phone numbers is in the Rand McNally motor carriers version road atlas
Temp IFTA can get expensive if you can't get back through in the alloted time(2-3 days) for each state. I found that out when I went to NY for the '03 ATHS national convention. I gave up my truck plate and went Historical since I was gone 4 days and permits only lasted 3 days. I wasn't paying double to be legal both ways.
Ben
Ben, since you live in PA and Rob lives In IL what he finds out may or may not be correct for you. You should go to your state vehicle website and find out what is appropriate for you.
Fred
If I am not mistaken temp permits are like 15.00 a pop. could just base it out of Il then what I've been told by Dot is anything over 200 AIR MILES needs to be logged. and or crossing state lines. or hazmat. JJ keller is good. Also any company that does oversize over weight permits can also do Single trip and temp ifta. Some states also want routes to be traveled to put on the single trip permit for whatever reason even thought your not O.D. I use to use West Coast Permits for all my stuff. Also think you need to put not for hire on the truck.
yep, they're pretty sharp about that kind of thing- almost like they have ESPN.
If and when you make such a trek, you are already good for ILL. OK, and TX should not pose a problem. On the other hand MO could, and NM probably will. I promise there will be more of a problem with NM. You will have to clear a port of entry in NM, and you can pay any fees there, You would be better advised to call each state DMV to see what each requires. Permits can be faxed to just about any truck stop through a permit service. But a permit service can not tell you what kind of surprise can be in store. Knowing how nasty they could be, when I brought my RS back from Oregon, I elected not to fool with NM , and saved almost $200.
or bring a inverter and printer have everything emailed to you or have a fax program and print them out. Truckstops get real expensive. We print all permits and scan in loads from the truck. Downfall you need a signal
Rob you can buy a permanen IFTA permit good fromJan.1 to Dec.31 it is only $5.00. You are required to fill out quarterly fuel reports even if you ran 0 miles in quarter. Another requirement for IFTA is you have to have apportioned plates and run in at least one other state for the byear or they will cancel your IFTA Permit. This happened to me in Penna. they did give me my IFTA back after they checked my records. I think rules for IFTA are the same for any jurisdiction as that was the reason for it. Joe D.
How do you trucking guys make any money with all these rules. It will drive you crazy. Best bet, I would think is put a "not for hire" sticker on the truck. The IFTA stuff I know nothing about. Does it apply if you are not fore hire.
You haven
t even made a dent in the rules here, try oversized, every state has different rules on width,height,length,rear over hang,lights,flags,night,sunset,half hour after sunset,axle weights, axle spacing, One amber strobe in rear,two in rear,one on each corner of load,flags on load,flags on truck and load,oversize load banner, wide load banner, each bridge has weight restrictions, some you pay to cross, some they close and escort just you, some no problem,DC and Maryland you have to call ahead on most bridges. One I crossed the other day was $100.00 if you were there for 10 am or 2 pm, if not you could cross at 6 pm for $600.00, can't leave the permitted route even for fuel unless you permit the exit and entrance back on,and the list goes on, it's endless
