1 hour ago, Joey Mack said:
th?id=OPHS.iEu7sXDMy%2f8bNA474C474&o=5&pid=21.1&w=174&h=174  yes indeed you need a liner puller. I used this one in the shops then bought one of my own. I paid $1000.00 for this tool 5+ years ago. and Freedom Racing has it for $600.00.. I used it on an ENDT 673, aside from all the other Mack engines.
I know you are talented in making things. For a few Mack engines that I have pulled sleeves on. I made a liner puller for the cost of a 1/2-13 threaded rod, maybe $5 at the time. 5/8" if you want to be heavy duty.
All that is needed is a piece of 1x2 or so bar stock. The bottom piece need to have the four corners go under the lower edge of the sleeve and be taped 1/2-13 in the center for the treaded rod. You can put it in the sleeve from the top. the top piece needs to be wider than the sleeve and have a clearance hole 17/32 for the rod. A piece of the 1x2 is welded or screwed to each end of the bar stock and clear the sleeve. Double nut the end of the threaded rod and wrench it up. All that is needed is have the sleeve move manybe 1 inch and it is unseated and come out with your hands. this will save $1000 for a puller that you  will use just a few times. To install the sleeve turn the top piece upside down ontop of the new sleeve and Dead Blow it it into place.
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579783
I have the same tool from Apex, had it for years. If you have one liner to pull, on Saturday afternoon, you can try some of the Make Do methods. When you have 6 or more liners to pull, the tool is worth buying.
Yeah, if you only are working on one engine with one bore size, you can make your own.
 Problem with threaded rod, most often it is course thread, which is not what you want to pull with.
 I feel the same about buying "clam shell, or tapered cone" ring compressors. Yeah you can do an engine without or with a one size fits all, compressor, but when working on an engine like that, the correct tool make the job much easier.
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579791
JoJo pointed to a place around $600, which is what I paid all those years ago.
Yeah, I've pulled dryliners out of one block to put in another. That isn't the point.
I forget how many blocks Larry has, and at some point the rationale that "I only have this one" to do, falls apart.
Having the right tools not only speeds thing up, they can prevent damage. A liner press over beating the liner in, not only gets it seated without damage to the top, it can alert to problems when it doesn't press in smoothly, that might be missed when hammering away. It can hold the liner in the installed compression to check protrusion.
A liner puller over a weld bead, can get the liner out without risk.
Yes if you have a lathe, you can make a damn fine liner puller for that bore. A fine thread and a thrust bearing, and you have something every bit as good as that tool above. If all you are going to work on has the same bore, you are set, but you'll have to make another "slug" for each additional bore/block type you work on.
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579804
4 hours ago, Geoff Weeks said:
I've made special tools for the Gardner's, for Leylands for the Kubota. Nothing wrong with home made. Sometimes the time it takes to make one that is as well made as a store bought one, uses time better spent elsewhere.
A round "slug" at the bottom sized to fit the liner bore can do a great job... if the crank doesn't get in the way. A "rocker" type that can be passed down through the bore from the top can work with the crank in place.
The ones with adjustable legs and two thickness of "feet" to grab thick and thin liners works on multiple engines with one purchase. Crank in or out.
I chose one that would work on multiple sized engines, although I used it most on 855 Cummins blocks.
After pulling so many liners, the $600 is soon forgot, the ability to pull a liner next to a head that is still on an adjacent cyl has paid off a time or two.
I'm not saying you HAVE to purchase, and you can easily copy one if you have the material and shop to make one, but a well designed tool makes the job go so much better.
I have plenty of home made tools in the box, for special applications.
Do a job once, try and borrow a tool, do it twice buy or build a tool.
If you know any one with a lathe a guy could knock one out in an hour or so a piece of 5/8 plate chuck it up and start cutting!  If you got a bud or even your own!
just sayin
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579824
If I understand correctly, he is doing at least all six liners. Making or buying a tool would be best.
A single liner, I have used a burr and cut two slits almost through, then knocked out a section to curl the liner in on itself. Lots of work but less so than removing the engine and crank from what I was working on. Lot of "clean up" work to make sure no "grit" remains behind.
 Mild steel deforms easily so has to be thick enough where it hooks the bottom of the liner to retain its diameter.  Harder steel can be thinner.
Pilot is a must to keep the puller on center.
The larger the area in contact with the liner, the less you have to worry about deformation.
It is why mild steel slugs work well and why pullers like the one pictured use replaceable hardened lugs, because the contact area is so much less.
Many ways to "skin the cat" what works best for you depends on how many you do and how fast you want to get it done.
Dry liners tend to be thinner than wet liners giving you less to grip on. Many engine shops prefer to use a boring bar to "bore out" dry liners, as they say there is less chance of damaging the block, like putting a gouge in the bore where the liner sits. They have the advantage of the engine out and the machines at hand to do the job.
 I have run across a "stuck" liner that sheared on of my puller lugs before. It pulled other liners from the same block without problem, but that "one" required a fresh set of lugs. Never know what you will run into.
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579845
Yikes!!  It is now $2100.
https://www.freedomracing.com/pt-6435-liner-puller-tool.html
Definitely will be fabbing something on my own.
Yes, work at a full outfitted machine shop.  I can build anything.
I only have this one engine to rebuild so, again, no sense in buying the tool.  No one will buy it used to recoup my expenses.
Did I read that these dry liners will slip out once they move a few inches(like a wet liner)?  Or do they come out tight the whole way(I figure).
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579851
Wow, goes to show that some places will gouge you for every cent!!  Pays to shop around.  Thanks Joey, I will spend that kind of money.
I see a difference in part number 6400 and 6435.  Wonder what this is about?
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579854
Holy crap, it is $2100.00 at freedom racing. I cant explain why during my search i saw it for $560ish on the search page.  I didnt go to the web site.. I'm sorry,  i just learned something about searches..
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579855
Interesting.  Here is 6400 part number at Freedom.  $590.
https://www.freedomracing.com/am-pt-6400-c-cylinder-liner-puller-assembly-tool.html
I wonder what the difference is between the two part numbers?  Says Cummins and CAT.  But ONI lists it as Mack?
What is the bore difference between Mack and CAT?
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579858
lots (lol)
https://www.bigmacktrucks.com/topic/75768-300-rebuild/page/7/#findComment-579860
