Mack AI460 AI427 AMI low torque low horsepower poor fuel mileage granite , dead dog , remediation
On 9/23/2019 at 10:19 PM, Bigjohn4300 said:
Ok, so ive been saving my nickles to do the 5 inch exhaust(my local truck pro can get them, has already quoted), exhaust manifold, K&S injectors and 400 turbo, but i just read something that concerns me, if my local dealer has the "Grey Motor Amnesia", does that mean that installing the parts wont help? Or just that it would run better if it had the dealer tune it after?
Just curious, if there was a way to convince the engine brain that the engine had boost, say 10 lbs or some low number like that, by fooling the boost sensor/manifold pressure sensor electronically, would that allow more fueling earlier? Maybe allow the actual boost to build quicker, minimizing the low end lag? Maybe a resistor or something in the circuit? Im not interested in rolling coal, just thinking aloud
Called 3 places today asking for quotes for the front and rear pipes:
1. Carolina International Trucks, Florence SC
2. FleetPride, Wilmington NC
3. Truck Pro, Charleston SC
**Carolina International Trucks — called back within 15 mins best price by far 843-468-9560
$250.00 FRONT MK-41112M2-5
$260.00 REAR MK-5110A-5
Fleetpride out of Wilmington NC came back with a quote of
$305.00 FRONT
$325.00 REAR. PLUS FREIGHT CHARGES
TruckPro never called back
Edited by The Burren
  • Thanks 1
On 10/3/2019 at 10:13 PM, Bigjohn4300 said:
MK 51105a-5                         $331+tax
MK 41112M2-5                     $315 +tax
M-132  direct fit muffler      $127 +tax
these prices are delivered to the baton rouge Truck Pro
Your rear pipe number is different than mine.?
I went off this
The custom Grand Rock, CV713, single run, exhaust part numbers are as follows:
  • MK-41112M2-5, 5" 2-BEND W/BELL FLARE & PYRO; ALZ  (front pipe)
  • MK-5110A-5, 5" 4-BEND W/LIST & WELDS OD/OD; ALZ    (rear pipe)
My Mack Dealership prices, w/mark-up, are as follows:
  • $206.99 front pipe
  • $221.03 rear pipe
As far as the “Turbo “ pipe ( pipe coming off the turbo) The very first CV’s with regular ETECH’s ( very few made) their pipes were 5” in diameter all the way down under the cab to where they necked down to 4” where the flex pipe slid on . On the  CV’s with the AI engines, the turbo pipe necked down to 4” right behind the turbo. The original ETECH pipe is still available through Mack and will fit the CV’s with the AI engine but is really tight. I used this pipe for a buddy’s 2005 CV and chopped off the 4” necked down part and did a full 5” flex and fab’ed up some elbows to a full flow 5” in/out muffler. We experimented with some software (. 427 Australia file)  along with the exhaust but he sold the truck before we could see if it helped the performance.
9 hours ago, The Burren said:
IMG_1684.thumb.JPG.717029d18aef1a3498214cbcfb8820d2.JPGIMG_1657.thumb.JPG.cd49aa4740e3a088eeda1d25c6c21fe2.JPG
WHAT? No broken studs? Those two old ones are going to start bothering you....better crank on em! 😉
Did you take Mackpro's cue on replacement of the rocker shaft bolts? They have a history of snapping and killing the camshaft. Be easy to R&R one at a time.
Edited by Mack Technician
Did you take Mackpro's cue on replacement of the rocker arm bolts? They have a history of snapping and killing the camshaft. Be easy to R&R one at a time.
Wait a min.. where was that Cue on rocker arm bolts...
K&S injectors installed
YTS Turbo in
exhaust manifold on
New rocker shaft bolts
Dual 4” pipes replaced with 5” Grand Rock exhaust and M-132 muffler mounted
Doing king pins tomorrow morning
Still need a pyro, but for now I’m just going to plug it up.
All in all coming along AWESOME!
Who’s thread is this again?
I’m sending you a beer.
YTS Turbo in
exhaust manifold on
Lol, while you have it stripped for kingpins you better add an extra leaf to the front right spring to support that turbo, we don’t want to create a lean!!
Careful about running with no pyro, it’s your insurance policy against a blue turbo.
Old Milwaukee.
Old Milwaukee.
Ha, Old Milwaukee.. no surprise there;)
I remember drinking many a Milwaukees Best...
A year supply headed your way!
10-4 on the pyro!
On 10/25/2019 at 12:47 PM, brettj3876 said:
What's the specs on the turbo you got? Looks like it will flow a ton better and keep egt's in check
 Mack Tech pointed me to this thread
I ended up using his same turbo which I believe was a borg warner S467 with a billet wheel.
Its a little bigger than the s300 and definitely spools earlier and flows nicely.
Im no expert but the larger exhaust manifold and GR pipes in conjunction with the turbo and injectors from K&S have really made this truck a pleasure to drive
How much boost you pushing with that s467? On our 93 with the S475 (171702) we see 42 psi. Have you considered getting the blixxton 200? We have on the 99 460 E-tech and boy it brought that baby to life.
Edited by brettj3876
