Days Won
29
Content Type
Profiles
Forums
Gallery
Events
Blogs
BMT Wiki
Collections
Store
Everything posted by Mack Technician
Mountains and retro-Mack hippy vans......must be Oregon?
Lol, he shall return! He's long standing (2013). Yeah, reverse oxbows, fuel vs torque. Congrats on the newborn Joe!
for E-Tech see attached...……. .E-Tech 427.pdf
Click on link.....Bottom of page 4 for AI427.
Maxidyne may be more right than you think...... An hour ago my boss came up to me and said "Hey, Jason, could you sign your CDL verification waiver for me....aaaaah your covered with grease, I'll catch you tomorrow". I said "Hey, how about I let it go, I'm barely doing any driving off-facility anymore.". He said "sign it, your one of only a few people here who can drive our standard transmission trucks". Ends up almost all but two of our yard workers/hwy drivers used an automatic to get their CDL and now have the Manual Transmission Restriction applied to their license. If Terry, Joe & Rob are going to be mixing drinks tonight I'll take Purple! Cause I have a soft spot for those finicky, expensive, stiff-shift, synchro-puking, triples too. Then we can work on a plan to lobby a federal CDL endorsement "MT" (Mack Transmission) for people who can drive a Mack triple.
You have active codes? Amber warning light on?
T300 series got to be quite a bit better than the T200 through development........but anyone who has rebuilt Fuller immediately recognizes Mack stole the T300 slider-clutch design from Fuller. No crime, it’s a better design.
Does it tend to want to hang around 900 RPM?
They’d give you a white helmet for saying that.
help with purge valve (spitter)
Mack Technician replied to mcratchet1's topic in Air Systems and Brakes
Follow you air governor line back to the tank its sensing pressure from. That's your wet tank. Wet tank gives air to both sides of your trucks air system and never takes any back. Wet tank has no monitoring, so temporarily screw a gauge in an open port on the wet tank so you can see what's happening there. Wet tank is isolated and is a relatively small cavity, 1/2 a tank in size, usually a split tank at low position. The governor only senses your wet tank since it's the supply to trucks air system, governor can't tell you what the rest of the system pressure is, it's only function is to make sure the wet tank is always full so rest of system can be fed off the wet tank. Scenario.... 1. Governor properly/accurately senses the wet tank....which (tank) is going low on air constantly - so fix origin of the wet tank leak. Your dash can't see what's going on at the wet tank either, so put a gauge in it. 2. Governor has lost its mind and is failing (AKA- Gavin Newsom syndrome). It's new, but that doesn't mean it's good. It was a topic the other day on here and I also had a new one that was bad out of the box last fall.... right from Mack dealership. 3. Any line leading to and away from the governor could be leaking off the signal governor is trying to send. For example: Governor can't send a large volume of air to a leaking spitter valve to unload it, or a leaking sensing line, or a leaking unloader in compressor head (which yours is new, so don't worry), governor can't compensate for the leak by sending more air fast enough and then you get a "drop out"..... a repetitive cycle of loading and unloading. Get soapy water and check while running...every sensing/control line. Note: I also only got one year out of my AD9 split valve and it blew out a seal causing wet tank leak down out the bottom of the dryer. crumby parts. -
It'll be the squiggly line you see inside the wall of a cardboard box which gives it rigidity. Special thanx to everyone who uses Amazon. Those Mack's have to feed the monster 2,850 tons of sticks & chips a day to keep him happy.
I wanted to visit Maine, now I'm debating if I need to move there? Can't quite make it out, but it looks like she's holding cold beer?
Sounds cool...……..but no pic showed up?
A bear is nothing but an overstuffed raccoon. They can’t leave anything alone. I was out elk hunting and came upon a cattle rancher who had his travel trailer demolished by black bear. I looked it over with him. Bear bit every water bottle once and punctured them. Open his tackle box and spread the baits everywhere. Tore a hole right through the aluminum side wall and squeezed in, spread a bag of flour all throughout the thing and tore the place to shreds. You could see he was “puppy chewing” everything for curiosity.
No programming, just put it in.
Maxitorque 13 Speed Shifter Knob replacement
Mack Technician replied to ivanuke's topic in Engine and Transmission
Get an 18 speed knob and your trans will become an 18 speed. The 13 just has a block pin in it to stop you from splitting low. Sales pitch...kinda lame they did that. The lines have push-pull sleeves. In other words if you push the ring in and pull line it will pop out. You must not have any air pressure or the line won’t want to release. They are like the shark bite pex fittings. -
Had a bad air governor right out of the box last fall. Makes you second guess yourself.
In freezing weather you do well to have an air dryer protected system. The other thing you need to consider is low pressure freezing. In other words compressed air moving from high pressure to low pressure creates ice. An example is the ice which forms on a carb Venturi on a hot engine. Just because you are in a warm climate doesn’t mean you can’t have ice form spontaneously in your brake system and cause trouble temporarily till it thaws. Rapid brake pumping could bring on a freeze inside an R valve plunger. The drier the air the better. On one hand you can argue it never had one. On the other hand they made a policy for installing them for good reason.
Buy all the government surplus flak jackets from the Vietnam era. Put cool GM emblems all over them. Have a famous, beautiful, model walk down the catwalk wearing one. Popularize the fashion and send them to Takata customers with a pair of designer safety glasses called “GM performance driving glasses”. That way tax payers won’t have to bail them out again and pay for someone else’s air bag recall.
Zach Brown’s new Anthem
Mack Technician replied to CaptainCrutch's topic in Modern Mack Truck General Discussion
The air compressor problem started in tandem with Volvo getting rid of Mack’s Renault engine coolant SCA filter. They didn’t think there would be a payback on the removal of it. They soon found out they were not getting the engines properly cleaned and without the coolant filter to cover for them the free agent casting sand would settle in low areas of the sleeve gallery, plugging the air compressor feed. The solution was an elbow fitting with a stand pipe which allowed the sand to settle in, but not cover the ports feed. If you have a 90 degree stand pipe fitting in the motor, and you’ve done your best to flush, you shouldn’t keep burning up compressors. If you have a coolant filter your golden. Last two winters we’ve had Volvo front loaders that have lost heat in the cab. Both times it was casting sand plugging the heater core. Kinda like cups, they don't figure it out...even two decades later. -
1996 E7-427 exhaust noise and high pyro
Mack Technician replied to Deere Mack's topic in Engine and Transmission
Right back atcha. You have no dead holes.....power is good....pyro is high......engine makes a “pich” “pich” “pich” as if it’s a single cylinder and not a constant hiss of steadily escaping boost.... The intake has a small square pipe plug with, I believe, 1/8” NPT threads. Run a 1/4” airline compression fitting in and run it into cab window so you can check boost under load. let it cool and spray soap water on the exhaust manifold legs to head. Run it and apply more. Did you extract the active code blink? CMCAC-chassis mounted charge air cooler. -
Pretty slick, and a gold dog, AND it's snail antennas removed from the hood . -
Why weren't you able to follow through on upgrading injectors? "Snag"?
BigMackTrucks.com
Our Vendors and Advertisers
