Jay Leno's Garage - The Greatest Vehicle Ever Made
Was a good watch, Jerry cans were called that because that was the slang name for Germans in WW1 and they invented the Jerry can
The American copied Jerry can is a absolute balls up disaster and no one out side of America can work out how the U.S. got it so wrong
Especially when the U.S. got so many other things so right during WW2
For the U.S. people on here, the filler pooring cap hole is the main issue, it's to big, doesn't fit anything properly except the silly U.S. funnel and can't be used with any other jerry can
The rest of the world uses a copy of the German Jerry can so everything can be interchangeable and you can grab fuel were you find it
The U.S. jerry can was so bad of a design that something like 20% of all fuel carted in WW2 in jerry cans spilt
Pretty sure the U.S. persisted with their ballsed up design well after the Vietnam war
Good youtube clip, really enjoyed it
Paul
lol I have a steel Jerry can for my diesel fuel. It is kind of a weird opening. I never really gave it a thought rhyme or reason, but I did have to go order a spout to make it more convenient to put the fuel in the truck without spilling it everywhere
I have a new style five gallon plastic gas can and it is the biggest pain to try using I have some older ones that are probably 20 years old, and they work so much easier just a simple spout and a separate vent. Last year I bought a cheap battery powered pump and it real helps at my age putting fuel in my Kubota loader backhoe the fuel filler cap is on top of the hood area and lifting five gallons of diesel up over the steering wheel isn't getting any easier
i also have a electric fuel pump with lines but the mack doesnt have a battery by the time i prepare everything to use the pump i might as well just struggle with the heavy can lol,,,lifting it up over a tractor,,,i would definitely use the pump
A good friend's dad had a ford model jeep he restored. When I was young, I used to go camping with the neighbors and they had an old flatfender jeep two of my friends have flatfenders they still use them another neighbor has one stored in his barn for way over thirty years. When I was taking auto repair in tech school I rebuilt an engine from an old flatfender jeep did an 8 N Ford tractor engine too.
2 hours ago, Joey Mack said:
O. D.  i did the same thing. The new cans in my mind are more dangerous that the older plastic cans.  Id spill more gas trying to get them to pour.  I even did a road call for a customer who got the safety nozzle stuck in his car filler neck. He pulled the can out hard and the stopper broke off and blocked the filler pipe.
like everything else being made today; not only are the newer gas cans a P I A to use but are much thinner. I still have two older plastic gas cans :HD construction which can take more abuse in back of truck . keep one newer can for transport only or for filling zero turn  mower which has two fender mounted tanks with 3-4 in caps. remove the ridiculous safety fill from can and slowly pour allowing can to vent.
Proper gas cans are still manufactured. Most consumers would consider spending $70-100 for a single gas can ludicrous. They would rather just buy the junk and complain about it....
Made in Wellsburg, West Virginia. Essentially unchanged for probably 80 years at this point:
5 Gal Red Steel Safety Can for Flammables | Funnel | Type I | UI50FS | Eagle
With that said I own three Eagle cans like the one pictured below. They are not safety cans because they do not automatically close if it were to be dropped. However, they do prevent evaporative emissions because any time I open the vent or fill nozzle plug get a very noticeable pressure equalization. The cans I have don't release vapors when not being used and will last at least 2 or 3 more lifetimes. It literally can't be improved upon. I have never purchased a gas can in my life. The three I have came with the first house I bought. I will probably never buy another one.
Edited by 67RModel
I’m sure it’s the same company. I almost drove for them. They were somewhere in the North Shore of Massachusetts. My cousin was a supervisor over there at the the paint can plant I don’t think they’re there anymore. I tried to look them up on Google. They had all U model macks
The gas can I usually use for all my small engines is around 22 years old it’s plastic and I really don’t trust it anymore. I’m just thinking of throwing it out and getting another one just because it’s so old any suggestions?
Oh you Americans are so far backwards compared to the rest of the world when it comes to jerry cans
I can't help but shake my head in disbelief at how a country as advanced as America can be so far backwards with jerry cans compared to the rest of the world
Sorry I know I'm gunna piss most of you off, but it really is true
The genuine style steel jerry can is so simple and so smart and the chances of spilling fuel so small when using the correct funnel
The correct style of clip on spout, air breather standard and fuel rushes out in under a minute
They come in 3 sizes, 20 litre is the most common size
1 gallon, 2 gallon (2.5 U.S. gallons) and 4 gallons (5 U.S. gallons)
These jerry cans are the standard the world over, except north America
Even when they are full of fuel you can float them in water, they are painted inside and out so they don't rust, they do eventually
And as far as the modern plastic rubbish goes, well I'll just leave it as what it is
I doubt they'll last 40 years or more and most have a crappy filler funnel thing
Off to the naughty corner Paul
  • Haha 1
16 hours ago, 67RModel said:
If you want a a real fuel can with a flexible funnel thingy in USA you have to opt for a type II style safety can pictured below. In my opinion the Jerry can is flawed design. They are top heavy and tip over in transport unless they are strapped down or setting in the proper bracket. In the USA it is typical to set things in the bed of a pickup truck and head down the road without restraints. A full Jerry can would be on its side in 10 seconds or less. I get it they most likely won’t spill if laid down but I wouldn’t want to do it on the regular or have to strap them down every time. The cylindrical cans pictured are next to impossible to have lay over in transit. Also, the Jerry can has the top handles parallel to the direction of pour. Horrible. Especially with the largest size. The top handle should be perpendicular to the direction of pour as pictured below. I’ve used both. I would not prefer to use jerry cans if I had other options.
I could agree with you but that would mean that over 95% of the world's population is wrong
I guess a lot depends on what we have been exposed to during our lives
Paul
