1957 Mack B70 Dump Truck
1 hour ago, Red Horse said:
Jim-Never saw that before-this year at NH show?  Is it an "X" with with big rear?
Yes, this was the Granite State show 2018.
I was right there and didn't check the tag.  Dunno why???  I don't believe it is an X though because it is running tubeless rubber and an X should have tube type 24" rubber.  There is no tubeless rim for the 24" spoke as you know.
25 minutes ago, james j neiweem said:
Beauty! Questions. Doesn't appear to have a long hood. Why the thermodyne emblam? Was it converted to diesel?
The B-70's didn't have a long hood.  B-70 was the same hood length as the B-61.  B-71 and up had longer hoods.
Thermodyne represent overhead valves so the emblem can be on either gasoline or diesel engines with overhead valves.  A B-20 with a flathead engine (valve in block) would be a Mack Magnadyne for example.
I am near Keene which is the other side of the state.  Went to school at UNH/Durham several decades ago.
The seacoast is always booming with activity plus Rt. 95 is the way in and out of Maine.  Definitely lots to see.
