My R model doors with the old style latch keep giving me hell...
Is it possible to convert from the older style door latch to the new style?
I see you can easily  swap over to the new style latch on the door panels  but the new style striker looks like it was revised to mount in the door frame?
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/
In 1979, the door changed slightly.  A new set up can go into an older +3 cab but the door lock mechanism was relocated so it won't line up.  Door will work but won't lock.  With mods yes, bolt in no.
The latch for yours should be 62QS424R if you try the new style.
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/#findComment-371424
Its been my experience the older style latches are better the doors rattle in the jambs with the new ones. All our RDs at work mine included the doors rattle in the jambs its really irritating I have tried everything short of replacing the hinges to fix the problem.
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/#findComment-371440
But I am correct in saying there were only 2 styles of latches used? when did the current style latch come into play?
5 hours ago, kscarbel2 said:
My experience is the old style latches* work as well as the new style.
* 62QS324C (right)  /  62QS325C (left)
Have you replaced your catches*?
* 31RC39B (right)  /  31RC310B (left)
I have seen some that were flawless. I replaced the latches but not the catches...will see if I can still get them and try that first
we must have the same issue but with diffrent style latches. My drivers side door works ok but I still have to push hard on the outside button to get it to open. the passenger side I have to use the palm of my had to get it to pop and from inside I cant even open it unless I try to rip the handle off the door
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/#findComment-371443
  • 7 years later...
  • 9 months later...
Well im at it again.
My passenger door Is on the fritz again. Another New latch and new catch. Thats twice in 10 years and the truck has only moved a handful of times.
It was like this when I bought it and has never improved even with new parts
Door shuts around frame perfectly but I only get one click and then it rattles like crazy. If I slam the door it might rotate the latch to get 2 clicks maybe once out of 50 trys but you have to slam it and then it won't open unless you bang on the inside with a rubber mallet.
I have tried adjusting the catch in the door frame but it only gets worse the more I mess with it and then the door can pop open when driving because again it only gets one click and not 2 when shutting it.
I think my catch was not installed in the door frame when this truck was new?
What can I possibly be missing?
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/#findComment-580216
Put it together without the outside handle on. See what happens. If it works ? the  rod from the  push button is a hair too long.
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/#findComment-580223
never heard of such a thing ;BUT based on the comment "If I slam the door it might rotate the latch to get two clicks" I;d look at wrong door foam/ rubber being to thick. not logical but slamming might be forcing tighter closure>>> once the words =change over show up !!  nothing is right. found that on a 40-59 yr ols new holland hay baler this week. bearing set up was a changer over !!  would have been nice for a parts boy to let me know after hrs in hot sun !! WTF this isn't right.
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/#findComment-580239
Similar issue with my B.
Drivers door has always been a PITA.  Most times you have to bang it with your shoulder to get it open from inside.  One in a while it just clicks open without issue.  I have ground on the two latch paws with some luck.  It is different from your R but still a bitch.  The passenger door works flawlessly like a new Cadillac.  Just click with two fingers every time.  I've jacked the door frame with a bottle jack to widen it and it seems to help for awhile.  I've polished the two ramps in the door frame portion with some luck also.  Never lasts long.  Even with my new door shells it doesn't fit well.
Aggravating.
https://www.bigmacktrucks.com/topic/50062-r-model-door-latch/#findComment-580251
