weight limits
mowerman
ok so im not feeling good enough to go work outside,,,,which sucks big balls because today is absolutely perfect weather,and like most of us,,,these perfect days will be going away soon,,,,,anyway,,,while back we were discussing weight limits on twin axle trucks and bridge laws and 34000 limit.... i have been wondering for years alot of us,,,including myself are running shorter twin drives,,,,,well just what are you allowed on the drivers,,if its not setup for bridge law,,,anyone know?????
does anyone even go by axle weight any more.?? now that you brought it up, thinking about it most go by GVW .  haven't seen the portable scale trucks much lately. possibly enough money is made with other paper work being wrong .  yrs back CT was making money with the axle weight gimmick.
You're allowed 34k on a set of tandems, and 20k on a single axle (including the steers IF the tires/rims/springs/axles/shackles/etc are rated for it). Your weight might be limited by your overall length...the bridge between the steer and drives...but that doesn't affect what the individual axles can carry.
For example, the feed truck I drive has a 20k steer & 46k drives on camelbacks. There's a tag axle behind the drives, but it's only far enough back to allow 43k on the drives with it lowered. If there was a little more distance between the front drive and the tag, it'd be 45k. With the allowable axle weights of 20k steer and 43k drives, I can run 63k without getting an overweight axle ticket...but because of the overall bridge between the steer and tag, I'm only allowed 61.5k before I'm over on gross weight.
If you're a T/T, there's a nice little exception that allows 34/34 on the drives & trailer tandems for an 80k gross weight despite being a little short...allowing for 39 & 40 foot trailers to gross 80k. What a lot of folks don't realize is that those same 40' trailers that have a spread axle can only legally gross 78k because they don't have a pair of tandem axles as required for the exception. They have 1 tandem on the truck, and a pair of single axles on the trailer...so while they can legally put 40k on the trailer axles instead of the 34k allowed with a tandem, that means their drives are limited because they only have the distance to haul 66k on those 4 axles (drives & trailer) instead of 68k through the use of the exception.
The feds have a nice little chart, and a pretty thorough explanation:
https://ops.fhwa.dot.gov/freight/publications/brdg_frm_wghts/
Illinois still uses the portables. Got pulled over & weighed last year on 'em.
yup, nu yawk bridge nazis make their own rules too.
just because truck manufacturer says it is good for 81,000 dont mean squat. the bridge nazis say you are only  allowed 53,000 because if the pusher axle in not at least 10 foot from steering axle it is not considered as a legal axle.
In pa, bridge law applied unless you register for 73,280.  I had a tractor with a short trailer, by bridge law I figured I was legal for about 63k despite axle ratings good for 80k. With 5 axles, steer, drive tandem, trailer tandem, I was not allowed to carry as much weight as a triaxle is allowed with only 4 axles and a shorter wheelbase? Really?  Loaded I was 75k, all the tanker trailer could hold. If I had ever gotten pulled over and called out on it (I was pa only on that rig) I would have taken it to court and asked the judge to get an engineer to explain to me my above math.
 I’m also starting to wonder if some states are just bypassing the axles and going by overall weight , Utah port of entry Is the only one I know about I passed my meet driver off A trailer while back the front box was overweight  2000 pounds for a single axle, he took it over Bonneville scale and went right through funny part is he really didn’t even give it a thought I told him it was too heavy just to let you know.? Great answer fellas. Thanks for that. Bob
But they tell me they inspection station is a real pain in the ass these days leaning on us for everything I don’t know what’s up with that
for those of you that don’t know anything about it it’s just a chickenshit little one bay inspection facility
here in jersey the scale on 287 north in piscataway is usually open during the day.  A LOT of trucks go around it.
especially the ones that should not be on the road. so the troopers took over a closed down business along the road the trucks were using to avoid the scale when the sign said scale open.
and besides getting a full white glove inspection, they also got tickets for avoiding the scale.
i got off the exit before the scale once around 10-11 years ago with sign lit up and turned left instead right like most did.
a trooper saw me and flipped around and came after me. just as he caught up to me i pulled into a company. he followed me and demanded i go to the scale and said i was getting a ticket for bypassing the scale.
i told him to go inside the company and tell the owner i would not be getting loaded as he was forcing me to leave and go to the scale. that did not make him happy, but he realized i had him.
15 minutes later i was pulling over the scale loaded. he say me and came out apologizing, and also to tell me i was 0nly 71,000 lbs when i was registered for80.
i than explained to him i was paid by the hour and not by the ton or load, and i kept my truck clean and maintained and NEVER went around scales or inspection stations.
i have full maintenance records in the trucks, and also the inspection records from the few times i was inspected by troopers where nothing was found wrong.
most of the troopers know our trucks and company, and just wave up past now.
See, that's where they get you. They used to sit at the exit before and the exit after and be on the radio with each other. If a truck got off at one & on again at the next too quickly, they'd be harrassed for going around the scale. There was also a fuel stop in between that the smart drivers would pull into, and either grab a bite to eat or top off their fuel...SOMETHING to have receipts showing they stopped for a legitimate reason. The smarter drivers were already off the interstate and stayed off another exit or two. I prefer to run the 2-lanes over the interstate, and so I just don't have to worry about many scales. If I do have to make a longer trip, I plan my route to keep away from any scales. They can't get you for dodging something that just isn't along your route.
Ha ha well I don’t quite know how to answer that one but yes, some of the scales could be a real pain in the ass. What surprises  me were pulling triple trailers through their scale I don’t know why they wanna deal with all that.6 pieces we have a check station just out of Reno that is open a lot, but they don’t like to mess with us on kind of the same reason there’s too many pieces easier to do a long box
I'm so used to going around scales, I was driving down the interstate in the Suburban with the family on board and hit the exit ramp. My wife says "where are you going?"
Yeah, there was a scale ahead. Old habits die hard.🤦‍♂️
  • Haha 1
As long as your not driving on no trucking roads I don’t see how they can harass you,it’s still mostly a free country to drive where u want..🤷‍♂️😡
the new driver got spot checked at the southern inspection station this morning.
the only thing the found was a slight flat spot on 2 of the 4 trailer lift axle tires, and his medical card expired last week.
when he pulled onto the job with the written report and no tickets, i called and ordered 4 tires to be delivered to the job and installed.
another advantage of the senior yrs (i guess) and retired. never had the brain power to run two logs(paper days), using a day cab and having the NJ run; would run 12=14 hrs straight through with the goal of getting through NY before traffic. had to show a motel layer over since I didn't want long wheel base sleeper. never stayed in a motel once except on paper. got the unit home on a friday 1=2 am ; spend Saturday redoing the book. had to take another book open staples to add more charts once. oh the fun times.
One of my favorites, I stopped off at the Houston yard to drop a load & grab an empty before booking it on down to Laredo. Got back to Houston where my truck took a break while I scrapped the trip to Laredo & continued on my way home. The truck caught back up to me the next day, and I made sure the logs matched what the company needed to see before sending them in. I only ever kept 1 book, and made sure whenever I was driving, it showed me legal. Slipped up one time, and wouldn't you know, that's the time I got busted. Hotel where I'd usually stay was booked up, so I slept under a tree in a field. Woke up, played with ol' Dozer for a bit, and was getting bored waiting for that ridiculously long 10 hour break to expire. I left after 8, which was all that was required when I started driving, and was only 5 hours from home. Turns out, I was 15 hours from home. Cop caught me about 30 minutes into the trip. So, I got a motel room and watched TV for 10 hours getting good & tired before rolling home in the evening when I'd be fighting heavy eyes the whole way home because obviously that was a lot safer than just letting me continue on my way home in the morning when I was fresh and alert after having slept all I was going to sleep that day.
i never go more than 100 miles from home base so do not need to run a log.
the new truck came with an elog built into it. i told them to disable it as i do not need it. dealer refused. so i deleted it from the computer when i got it home.
