E6 vs E9 MPG
I'm wondering if anyone knows which engine would be best for MPG in a hobby truck that will be lightly loaded 99% of the time (maybe hauling a couple of antique pickups on a drop deck trailer or a fifth wheel RV or similar).  Not looking to haul 80,000 lbs on a regular basis, if ever.  Logically, I would think an E6 would return the best fuel economy pulling light loads but you often hear people say that large-displacement, lightly-stressed engines actually outperform the small-displacement engines for economy-- although I'm assuming that's pulling full-gross loads.
Does anyone have any experience with these motors pulling lighter loads like a hobby truck typically would?  I've always thought an E6 would make a lot of sense in a hobby truck but I want to make sure I'm not missing something.  Thanks for your input!
I never measured my fuel consumption on my E9 MH, I doubt if it was better than a six, my only concern was getting the cooling system to come up to temp when bobtailing, that alone will make fuel burn inefficient to a point where I was going to blank off most of the rad to see if it helped.... loaded trailer, no problem.
For sheer "grin factor" on a hobby truck, go E9, but just consider how much it will cost to repair if it goes bang, then you wish you had a E6... LOL
BC Mack
That was their thinking years ago, to run a big engine with a small load for fuel economy. Hence the cummins k19 and 3408 cat as well as Mack v8.
But fuel economy is a speculative thing. Unless you can compare the two on the same day, with the same load and the same driver you will never have a true comparison. And the difference would be bugger all when empty id say.
I would have to ask Ray what he gets bob tailing or dragging his empty flat bed.  I do know a 300 mack with a mack 9 speed overdrive got me in the high 6's with a empty van trailer from Long island to Chicago. never did get good MPG with a 300 and direct 6 speed best I think was 5.8
17 hours ago, MHfred said:
My E 6 300 with 9 speed O/D and 4.0 rear will get right above 10.0 bobtail.
That's about what I had with my E6-350 R-model bobtailing for nearly 1500 km. T2090 0.71 OD tranny with 5.02 rears on 11R24.5.
Here we use a different style of counting consumption. How many liters you burn passing each 100 km. So I had to do some math.
Personally I wouldn't choose a model of a power plant for my hobby truck basing on fuel savings.
I'd like an engine which seems rare or interesting/unique of its design, or has its special heritage. This is my approach.
Or if I'm not much into technical aspects of collecting trucks and more enjoy just their look I'd go with a common, simple and easy to maintan model of the engine.
I'm pretty sure fuel you use driving a hooby thing is a relatively small loss of money relating to other matters along it.
My superliner with e6 350 "pump has been played with not by me previous owner had to of" t2100 10sp with 3.86 "I think" 11R22.5 I average 6.5 running 65-70 or almost 7 if I never go over 60 during the day. That's 80000ish one way empty coming back pulling a low sided hopper
