School Me On CB Radios.
I need to choose a CB. While I'll be doing some OTR driving in the future, (both U.S. and Canada) most of my driving will be in state. I pull an end dump, and I'm constantly in gravel pits, and concrete and asphalt plants. Communicating with the dispatchers in these places is a must. The signals in those places can be weak. So if there are any features to help deal with that problem, I would be interested. Weather channels would be nice, but between the Weather Channel app. I have on my phone, and available channels on my Sirius Radio, they're not necessary. I'm not looking to spend hundreds of dollars. Just something effective.
I run a stock Cobra 29 LTD with a Wilson 2000 antenna. I tuned it myself, easy and works great!
I paid about $110 for the CB and $57 for the antenna.
For another $40 I did add an external speaker but by no means was it a necessity.
Like others have stated a general cobra or uniden or something along those lines will be fine.   It's more important to have 1 good antenna with your swr's set within spec.    I would also recommend a noise canceling mic.   Just my preference.
Thanks guys and gal!
Yeah, when you pull into a quarry or plant, there's usually a sign at the entrance telling you which channel to use.
Now, as for an antenna, are the short ones any good?  I'm out in the country a lot. My stack smacks the low lying branches sometimes. So I know a long antenna will get banged around a lot.
Actually, now that I think about it, there's a short one on top of the cab already. I don't know anything about it.
Sorry to sound stupid, but what's the ground plane?
The vehicle metal ground surface under the antenna. It helps "reflect the signals,  the vehicle roof works best or a direct ground cable to the chassis.. A Dipole CB antenna does not need a ground plane like the No Ground antenna kit from Firestik
