B series fuel pump question
Hey all,
ive got a midsixties B75 with a thermodyne engine. I needed to use it but after sitting for half dozen years or so, it quit a minute or two after start up. Turns out the supply pump, APE,  wasn't delivering fuel. ..and the hand primer wasn't pulling in fuel either. Turns out the pump cavity was empty and, after filling it with diesel (pulled off the primer body and lifted the check valve) I got the hand primer working and pushed fuel up into the injection pump and all was well.
 But...now after a couple of days it's doing it again.. Won't run and primer pump won't pull in fuel and push it over to the filter. I probably have hunky old fuel, don't you think? I'll empty the tanks and put in fresh diesel and flush the line up to the pump. Any other ideas?
Also, are repair parts available for these little plunger pumps? Or even rebuilt units?
thanks for any assistance.
martin
Edited by martinf
1965 Mack B-74, dump
1974 Mack R, logging w/Prentice self-loader
www.somewhereonthemountain.blogspot.com
You also should inspect the fuel lines to see if they wet on the outside, damaged, etc. They may be given you a problem pulling the fuel up from the tank.  Old fuel lines can deteriorate inside and cause issues.
You can get reman lift pump from Mack.  I just put one on my 237 last summer.  Not cheap, but mine was on the weak side.  The primer pump is just plastic buttons(check valves) and sometimes you might just be able to take it apart and clean it and make it work again.  I've done that in the past.  Just unscrew the plunger part from the lift pump.
Thanks guys. All good suggestions. Just woke up to find it snowing hard so my Macks gonna have to sit for a while til it melts. Sigh.
martin
Well guess what came out of the supply line petcocks on both tanks? Molasses! I've never seen anything this bad before. A gallon of the blackest ooze you could ever imagine.
i haven't run this truck in 8 years and it sat lots before that. And when I got her running and parked it at my digging site to load with rock, she sat pointed downhill. And that ooze was filling up other fuel line between the tanks and half way up the supply hose to the pump. Poor pump...no wonder it couldn't pull fuel.
makes me want to paint my fuel tanks white so they don't become solar ovens in the summer sun all season year after year!
It could be general sludge or Algae,microbe or fungus in the fuel.I run an anti algae /  bacterial / fungicide additive in the fuel from Bell Performance in my trucks that lay idle for extended periods. Clean the tanks and lines you should be good to go
Cleaning the lines is easy, but how would you go about cleaning the tanks. I've drained them but fresh diesel is not going to dissolve that molasses sludge. I hate take them off and get them steam cleaned and tho gasoline dissolves the sludge, I don't like the idea of any leftover gas being in the tank when I refuel.
martin
