My Red Greene Moment
41chevy
AWW.... A LITTLE OF THE HANDY MANS SECRET WEAPON OTTA FIX THAT. LOL
TOO BAD IT DIDNT LINE UP WITH A STUD IM SURE MY WIFE WOULD HAVE JUMPED OUTTA HER JEANS, IF I WOULD DO THAT!
NOW RECITE THE MANS PRAYER ..... IM A MAN AND I CAN CHANGE IF I HAVE TO I GUESS.
A sickly dying squeek. . .
Yikes, you were lucky the stop never got put through the wall before you hooked up the alarm
The base board stop works , the can not so much.. worth it though she holds the door.
...since ya gots a hole ta patch anyways, cut the hole a little bigger...square it off so you can patch it easier. Use a scrap piece of 2x4 and run it horizontally between the 2 studs so that the door stop is in front of a solid piece of wall. Patch the hole, and try again with the air horn...this time it'll have a solid backstop.
