Not sure where to put this, so I'll try here.
I bought an old trailer several years ago and the tires are in need of changing. While removing the inner lugs; 2 of the square ends sheared off. Pipe wrench is a fail, so what other ways is there to get these off?? I cut down the side of one with an angle grinder, but couldn't get all the way to the rim. I'm thinking that I can't get to the rim with a torch either (w/o doing damage to the rim). This trailer has old skool brakes and would require a lot of work to replace the lug stud, if I just cut the stud off.
https://www.bigmacktrucks.com/topic/75807-budd-lug-woes/
There is a special tool that is made to get the inner nut off when that happens. It isn't 100% effective, but does work most of the time.
https://www.jbtools.com/ken-tool-30165-dual-wheel-lug-stud-remover/?wi=off&gad_source=1&gad_campaignid=22174825632
you pound it on and then wrench the nut off.
Once you have ground down one side, I don't think it will work.
just cutting above the rim may not do it. You may have to pull the hub, if inboard drums, and remove the nut in the drum and drive the stud out. If that is what you mean by "old Skool" brakes!
I think you may be to the point where you have to decide "what to destroy" to get the rim off, and replace the destroyed parts.
https://www.bigmacktrucks.com/topic/75807-budd-lug-woes/#findComment-579898
you got the outer nuts off which would indicated going right direction of thread ; not tightening inners due to left/right hand  . depending on how much you cut with die grinder . which is #1 method for broken removal. two ways which have proven successful :: 1- install the outer nut back on close to wheel and weld it to inner deep socket /impact try removal 2- drill number of small holes in broken inner nut close to rim . then the  pipe wrench. another reply just came in ; possible same.
https://www.bigmacktrucks.com/topic/75807-budd-lug-woes/#findComment-579899
being "an old trailer" going with idea these are steel wheels not alum which would have the thinner shank inner nuts. option two of drilling the bevel on inner nut allows for penetrating oil to soak threads/nuts , also weakens the inner nut. after drilling inner bevel . a few smacks with BF hammer at broken end helps loosen situation on occasion.
https://www.bigmacktrucks.com/topic/75807-budd-lug-woes/#findComment-579901
DON'T allow frustration to confuse the brain cells to point you do everything and still the MF nut doesn't move only to find out you were turning it the wrong way !! now who would do that ???😱😱. here I am folks.
  • Haha 1
https://www.bigmacktrucks.com/topic/75807-budd-lug-woes/#findComment-579904
