Trivia Quiz for you guys.
Go to solution Solved by HeavyGunner,
Can anyone name another application for a tip-turbine after-cooler set up other than Mack? The turbine appeared to be the exact same design too.
I saw it today, and was very surprised. (some on here may have known of them for a long time. . .)
International comes to mind for some odd reason. Interesting question. Paul
Here's a hint....This application would have been in service late '80s early '90s... possibly earlier too....
on or off road?
Aroud the time of Caterpillar/Perkins deal
Best I can tell, it was before that....
I need to say, the 'cooler box' is a different shape, but the idea behind the setup is identical and as I mentioned before, the turbine(fan?) is indeed the same...
Couldn't be the Diesel that converts fuel to noise and rainbow spots....
We had a pair of R model at Horans with them, biggest thing I saw was keeping the exchange fins clean of dust and schmegma from running in Broman's sand pit. Turbos seem fine. No idea for an OTR unit
schmegma.... hilarious..... You're definitely from L.I.
