5 hours ago, james j neiweem said:
They have a heavy spec Mack tractor. Its called the Granite. But nobody seems to buy them in a tractor configuration. I don't get it.
Because they won't give you a decent sleeper. Mack could have sold lots of Titan's and Granite's if they would have just offered the 60 inch midrise on them.
I had friends that had the HOS sleeper on their Granite's and they froze to death in them in the winter.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577476
That’s really weird because I just read a couple of weeks ago. They were not going to do anything with the anthem. I saw a brand new pioneer at the show. It wasn’t the ugliest thing I ever seen. I think the worst thing about it was the windshield I didn’t care for it was too bubbly, but you fellas are right. There is too much Volvo in it. Best of luck to them.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577486
There are plenty of heavy spec tractors from producers other than Mack that don't have sleepers. So why aren't there more heavy spec Granite tractors. Is weight the issue? I can see it for trailer dumps but not lowboys. Maybe they are under powered.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577516
I showed up at a train de-rail, with a 6-71 (238 hp) Fleetstar, and was getting razzed, the old semi retired driver for the H-H company said "we used to move super loads with that power'.
I used my Fleetstar because I knew I would have to go down an access road to retrieve the rail car. I took all the trailers down, turned them around and stretched them out for the other "large car's", on the understanding I would get the 1st load out! They ribbed me I could have the 1st load but would be last to be unloaded. The old gray hair said under his breath "don't you bet on it! You could here that 6-71 for miles, and I was the 1st to unload!
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577529
5 hours ago, Geoff Weeks said:
Pulling the same stuff we moved with 350-400hp!  I moved the same stuff the oldtimers (at that time) moved with 200 hp!
for 21 years i ran heavy equipment all over the tri state area with a DM800 powered by a 237 and mud stick trans. 58k rears with 14-24 tires on tractor and trailer.
with the "S" tags on the trailer, i was legal for 215,000 lbs total weight. i had a bolt on third axle for the trailer, but never used it.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577537
So,  I just retired from the Quality Group at the Mack Macungie plant.  Part of the groups function is reviewing new projects.  So, that said,  I first worked on the new Pioneer and the improved Anthem in Oct of 2023.  They needed completed truck cabs to send for the NHTSB crash testing.   The last one was a few days before I retired on January 10th 2025.  I know exactly what the new Anthem looks like, but ..... sorry,  I signed non-disclosure papers on the project.   I can say it rides real nice.  And,  both the Pioneer and the refreshed Anthem get an advertised 11% better fuel mileage (relative to how much lead is in your foot).   If you are still driving for a living,  get your annual fuel bill out and figure out what 11% is.
Are the Mack Pioneer and the Volvo VNL the same? Only sort of.   The Mack maintained the dash layout that is more setup for the working man (switches closer to reach), and slightly nicer trim levels.  It also maintains the engine programing that gives the truck better throttle response, leaving MPG up to the driver (there is times you need power like getting on a busy interstate).    They share many many body and frame parts, which can help save costs and keep the company competitive.    As for the new look, well I didn't like the look of the original Anthem when it came out, but it grew on me.  Same with the new trucks.
What I know about the Granite Axle back and both axle forward models (Pinnacle & Granite),  They are marked for updates but I don't have dates.   The update are part of the latest emission standards which has fuel mileage requirements.   As for the axle forwards, I was told Volvo does not offer an Axle forward so they don't fully understand why people want them.   Maybe they should watch the training videos Mack has on the different axle configurations and the why of them.  A rather boring video but good info.
The last Anthem sleeper rolled off the assembly line a week of two ago.  The last Old style Anthem day cab will roll off later this year.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577565
15 hours ago, Geoff Weeks said:
Only thing that has changed, is the tolerance for slow moving large loads.
Yep, I pulled 140,000 pounds daily with this old 88 R Model, 350 four valve, 15 speed. But I was down to 3rd gear on all our 7, 10 to 12% hills in the winter pushing wind and slush. Nowadays everyone has to go 70 MPH, which I believe is part of the problem with all the accidents now.
Put a seat cover in a rig with 500 plus h.p. pulling a freight van, with an automatic and a super strong engine brake and they really don't have to know how to drive. And now we see the results.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577584
Thanks for the info. I just don't like the new "shared with Volvo stuff" As you say, a lot of it has to do with fuel mileage and emissions regulations, but they just don't even look nice. No shape or styling, all flat body panels. And they don't look or feel like trucks any more. Too automotive, way too much electronics and gadgets. But I guess that's what the new generation wants. Just glad I don't have to buy or drive them any more for a living.
And they talk about distracted driving, yet all these new auto's and trucks have to have 12 inch tv screens in the middle of the dash that you can scroll through pages of info.....instead of nice simple gauges. The Rawhide was the last nice Mack cab and interior for me.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577585
What hasn't changed a bit from the early days, is the number of axles to haul the weight and therefore the number of brakes to slow the load. 140K, 170K at 70MPH with the same brakes that were used when the speed was 1/2 that is not an improvement.  More power will help get the load up the grade, but takes a good hand to get it back down the other side.
I once pulled Butte, MT westbound and was one gear up from bottom, I could have used more power! only had a 315 HP at 1800 RPM gov limit, if that.
Now we have big power, but still the same 7-8 axles and brakes under the same load.
More power and the temptation to grab more gears and speed when pulling a grade instead of selecting a gear and riding it to the top, Much easier to do damage shifting under that kind of load on a grade, then taking more time and pulling to the top a bit slower.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577587
Can you tell me what you think of the new improved mDrive and clutch? The information we were given stated the control housing on the transmission had been upgraded and the passthrough harness weak link eliminated, so we're all wondering if it actually would be better.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577598
well thanks for all your input,,,,mack trucks have most of us very impressed for many years,,with very appealing,,body styles,,,many thanks for many years of eye candy,i understand they are trying to compete,,,with new and exciting ideas,,,and the new body,is not the worse thing ive ever seen,,,,so best of luck to them,,,and hope they make a great impression on the younger generation,,,and catch on to big fleets and sell many of them,,,i took a good look at a pioneer at the museum saturday and i think they will catch on soon,,,as i mentioned...best of luck to the cooperation,,,,afterall they put out the new volvo ,that i thought was the ugliest thing i ever saw,,,and thier still selling tons of them to this day,,,,bob
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577619
3 hours ago, james j neiweem said:
T-Mack1-Do you know if they are going to continue making the axle forward Pinnacle(CHU) in the future. Would be nice to see this offering with big Cummins power to be competitive with the other axle forward manufacturers.
J Neiweem,  We were told that an updated CHU (now a PI) was under consideration.    I have no other info.
Next,  we were told that they will be offering more Cummins choices.  This is sort of related to the MP7 having issues meeting the 2025 emissions.  Although,  I think it may be the high HP versions of the MP7 (395 & 415 hp).    With the Cummins, comes the option of the Eaton "Endurant" Automated Manual Trans.   I've driven them but they hesitate between shifts more noticeably than the Mack m-Drive.
https://www.bigmacktrucks.com/topic/75649-new-mack-anthem/#findComment-577644
