END-673/711 and ENDT 673/711 HP&TQ ?'s
I was wondering what the power ratings were for the Thermodyne diesels ?
The END-673 ? ENDT-673 ?
The END-711 ? END+T 711 ?
Now I am new but I do know the 711 didn't have turbo's, They were a later add on/update or "retrofit"
Mike
1953 REO M48.
1962 GMC 3000.
1969 AMC AMX-390.
1983 AMC Eagle SX/4.
1988 AMC Jeep Comanche.
Thanks for the engine info, 170-250hp for the 673 diesels and 211hp for the 711 diesel.
I'm guess there isn't a power rating for the the 711's that got the turbo retro-fitted ?
I tried the link got me to a PDF file on B-Mack engine data my phone won't open it for some reason I am a mobile site user so some of the site may not work for me ;o(
Anywho, Thanks for the info guys
Mike
1953 REO M48.
1962 GMC 3000.
1969 AMC AMX-390.
So I'm guessing Mack never released any power numbers for the turbo charged 711 ?I haven't seen but 3 of them so I guess they number very few ? !Mike
I have a 711 with a turbo and been wondering the same thing. A old trucker friend of mine told me it should have between 230-250 but he's no Mack guru so there's just a idea of what it could be.
Rudy
The heads bolts are different in the corners on the early models. They will be 3/4 in the corners and on the later 711 they will be 20 bolts per head.
What Glenn said. 18 bolts were on the earlier then the fix for the blowing of head gaskets was more bolts to make a total of 20.
If you would pull the heads the 711 had a 5" Bore, where as a 673 had a 4-7/8" bore.
My great uncle guessed the turbo charged 711 diesel at 230hp/680tq he figured.
He said it was an impressively strong pulling engine, Just had to watch the rev's they didn't put up with lugging.
He said the one he ran loved being run up to 2200rpm than shifted and pulled like a snorting beast.
he was running one swapped into an army truck in place of blown ENDT673 so it only had a 5spd manual so it had to be rev up to avoid lugging it.
Mike
1953 REO M48.
1962 GMC 3000.
1969 AMC AMX-390.
  • 8 years later...
We had B models with end 673 170s/ tri plex Trans. Good trucks.  Then G models with endt 673 205s with tri-plex good trucks.  Then F models and C models with 711 211s dou plex uni shift.   18 bolt head mostly junk.  The 20 bolt head not much better.  Then R & U models with maxidynes the 5 speeds were weak but with a 7 speed worked out well.  My favorite was F model with Mack V 8 and tri plex 255 hp.
Ran a bunch of R-models with 250-horse ENDT-673C engines and 18-speed Quadruplexes.  Were very good, reliable trucks.  Real slugs compared to what they have today.  But, pretty good for the day.
170-horse B-models we had were tough, but slow.
