Geoff Weeks
Pedigreed Bulldog
  1. Found this: https://www.eaton.com/content/dam/eaton/products/transmissions/vehicle-transmissions/eaton-transmission-clutch-housing-selector-cmt1540-en-us.pdf It seams to imply that push and lower pull are NOT the same on the cross shaft (learned something new) and I can't find a push nodal mount for the older transmissions. SO I may be wrong. That said if you can fit a double disk pull flywheel, the trans with the nodal mount shouldn't be hard to come by.
  2. I THINK this is what you are looking for: Nodal mount Push and pull Clutch Doesn't say what model trans it came off https://www.heavytruckparts.net/item/Mack/-/Bell-Housing/297005/1/83669829 What I remember, but DO NOT go off my memory alone, that the newer model Roadranger trans bells are different than then earlier (pre RLO) -6 and older transmission clutch housings, although they look similar. edit: it doesn't look like the lower bosses are machined out for a push clutch, the bosses are in the casting but they haven't been machined.
  3. This is what you need I think: https://www.vanderhaags.com/detailview.php?part=25092981 Wait, that one doesn't seam to have the lower cross shaft holes, They have a few that are both but most are pull only. What is confusing is the replacement are all set up for either, but I guess the OEM are one or the other.
  4. Is yours #2 or #1? Measure 1st, there are plenty of drawings on the internet that show the measurements for the SAE bells. Eaton uses the same trans bell for push and pull, there are two sets of holes for the cross shaft an bushings. Top set are for pull, bottom for push. edit: this seams only to be true of "replacement" housings, original can be one or the other or both. Bells are the same for all the older -6 and down roadrangers, the lighter rated ones tended to be aluminum, the heavier rated ones tended to iron. So, in other word a RT11609 would likely be found with an aluminum bell but a RT14609 would be more likely to have an iron bell, but you could interchange them. I have an aluminum R/R bell but doesn't have the nodal mount you need, otherwise it would be yours. The trans can be switch from push to pull or visa versa by changing the input shaft and front bearing retainer.
  5. I know the 1st gen Volvo/White conventionals used nodal mount with pads for engine mounts on the trans half of the bell housing. A 4 bolt pad on each side not exactly vertical to which mounts were bolted.
  6. You can put washers on the 3/8" bolts when putting them through a trans side bell with 7/16" hole. The bolts don't center the bell, the ring on the inside does, so the "slop" makes no difference in alignment.
  7. Old #1 used 3/8" bolts (something Iearned about the hard way) at some point they switched to 7/16 threaded holes but all other dimensions remain the same.
  8. I'd start by looking up what the SAE housings and flywheel standard covers. You might be pleasantly surprised. The whole idea was if it was standardized, then anything that fit a #1 housing had to have the same mounting depth etc. The only push clutch I have dealt with was SAE #2. I'm assuming yours is #1. Getting the right Eaton half of the Bell with the nodal mount may be the hardest thing to find, as input shafts and bearing retainers are often changed as a matter of course when a clutch job is done. A internet search had a few hits from the common suppliers. I never saw the point in replacing parts that weren't worn beyond service ability, but my clutches often lasted until the engine had to come out for some other reason.
  9. FYI, I get a few hits for the push clutch bearing retainer (around $200) but almost nothing for the 2" push clutch shaft. If your serious, I would start looking for the shaft before going further down this road. S-1129 or S 1129a Did a little more searching and found alternate FBC and input shaft. Don't know the difference but both seam more available S 1660 & 20549 for part numbers I think I found the difference between the 1st set of numbers and the 2nd set. The 1st set uses a rubber seal on the input shaft and can be driven in either direction. The 2nd set uses a "screw seal" like the pull clutches and can only be turned in the conventional direction
  10. I thought, but never verified, that the SAE spec meant that the input shaft length and depth to crankshaft was part of the spec regardless of what flywheel and clutch was used. The input shaft for push clutches are different than the one for pull clutches, I know. I don't think the length changes though. After all the pilot bearing sits against the crank, and the spline on the shaft runs up to the pilot. The difference is at the bearing retainer end, the shaft has to run through the tube on the retainer that carries the throw-out bearing. Eaton's can be had with nodel mounts on the trans 1/2 of the bell, Volvo also used that arrangement. Having said all that, I have never seen a Eaton with a push clutch. However, you are going to need the push clutch shaft and bearing retainer regardless, if you have the trans already, then I would buy the shaft and bearing retainer and measure and compare to the trans you have now. You still need a Nodal mount trans half of the bell, but they should be out there, I know the Volvo/White/GMC (early 80's) used that as one place I worked had 2 of them, and I put clutches in them, and remember it was a pain having to support the rear of the engine while I did so. I think it would make life simpler not having to re design the whole clutch and linkage.
  11. They made one for the RR also that had an air cyl that pushed against the side of the PTO gear, but they're long out of production.
  12. https://www.inforanger.roadranger.com/index.aspx?modelID=426&groupID=799 https://www.inforanger.roadranger.com/index.aspx?modelID=426&groupID=937 Choice of 2" or 1 3/4" shaft https://www.inforanger.roadranger.com/index.aspx?modelID=588&groupID=916
  13. They can be made for a push clutch, but then you loose the clutch brake. Is the bell you have now made to SAE spec's? If so, I think you can use the single disk set-up with a push front bearing retainer on the trans. That would have to be "special ordered" as very few use a push clutch. The Bell on my 9 speed has the holes below the input shaft for a push clutch yoke.
  14. IIRC they had an "oil scoop" on the ring gear to dump lube on the power divider, the rears themselves didn't care, it was the P/D that took the brunt of it.
  15. Larry, I think you'll want a pull clutch, but I have no idea if the bells are the same or not. Are you looking at an Eaton or other mfg trans or a Mack?
  16. Few people do that as a service anymore. Used to be there were guys would come out to your shop and cut the counter bores in chassie. I never had enough to make buying the cutter worth the money.
  17. Yeah, I don't want them to go to scrap, and thought I had a buyer, but he kept putting off finalizing the sale and picking them up. Just a few of the parts alone are worth the asking price, Apex gov goes for over $1300 now. Used Jakes are worth a fair bit, heck even the starters are worth something. I ran the Big Cam 3 until it would not hold upper press fit liners anymore. My thought was to upgrade it by having it cut for lower press fit liners and build it back to 676 spec's. Now I have no need.
  18. Breaker Interlock is the cheapest solution, but is limited by the wiring to the input. Manual transfer switch is good regardless of generator up grades or load changes up to the service entrance capacity. It only needs to be replaced if/when the service is increased, like from 100 amp mains to 300 amp mains. It is the intermediate step between a full automatic transfer switch and a single breaker interlock. People change generators all the time, but rarely change main service capacity.
  19. Most places now a days have a disconnect outside of the house (most often below the meter). A manual transfer switch placed below the meter, while not as convenient as an ATS, is a whole lot cheaper. The switch needs to be rated for the full input of the service, but the generator connection doesn't have to match that. With a manual you don't have to "upgrade" when the generator gets changed out, but will not automatically start and stop the generator We loose power so infrequently and for short duration, that I have never bothered with the expense. Just run extension cords to the few things (fridge, freeze) we want to keep powered.
  20. I have two mostly complete Big Cam Cummins cores. Good enough to build one good engine with spares. One block is likely beyond hope, the other needs counterbore machine work. The one with a bad block (crack at rear coolant plug and had been run a long time with head gasket leaks) is a 400 hp CPL 676 Big Cam 4, the other started life as Big Cam 3. I kept them around as I was going to build to 676 specs (Last fixed timed 400). Both were "running cores" when pulled. Between the two you could build one good engine with Jakes either low or high flow cooling. The BC3 is missing the oil pump and oil cooler, but does have BC 1 oil pump and cooler, the BC 4 is complete. Mix and match parts how you like. Both have good cranks and flywheel/bells. One has Horton fan clutch, other has plain fan drive. One has Teliflex (Apex) Aux high idle governor. Also have an extra PT APC fuel pump, along with the two already on the engines. Plenty of good stuff to build one good engine. Western Iowa, Asking $700 for the pair but open to offers. Also have some Cummins tools that I would sell separate. I have a gin-pole truck I can use to load them on a flat-bed. Pm me here
  21. Yeah, the "N" was a neat set-up, but I think its weak point was high speed running, not a problem on WW2 trucks it was used on, but could be when re purposed later in life. I think that is why it was never seen later in civi production trucks.
  22. If the front lugs are 1/2", the nuts are still available last time I looked, but the bolts are not. They are a special bolt and are held in the spoke with a cotter pin. I think the 5/8" of the same style are still available IIRC. So be very careful removing the nuts not to snap the bolts.
  23. Up until the late 50's early 60's when the more common treadle valve came into being, this was what was used. I tried to get a photo of my Dart (early 50's) but couldn't This is from a military air brake manual
  24. Coupla things to add, In that vintage you can't look at the pedals and tell if it was air or hydraulic brakes. The air brakes were often controlled by a rod from the pedal. This allowed mfg to use the same pedal on air and hydraulic braked trucks. I could try and get a picture on my Dart set up it uses the rod for air brakes, but just the same you'd have to look to be sure. However the lack of visible compressor on the engine make hydraulic likely. Drums: inspect the drums carefully as it is unlikely to find replacements still made. NOS or expensive repairs made by pressing in a steel band to restore the drums if they are shot can make a big difference on how you proceed. Worn drums or other parts that are NLA may even dictate a axle swap is in your future, unless parts can be found. In the early years hydraulic brakes were used on much heavier trucks than they are today, air brakes were new and an expensive option that wasn't often opted for unless semi trailers were going to be towed, and sometimes not even then. I once saw a 40K GVW tandem axle Loadstar on juice brakes! Vacuum PDL!
  25. If the 24 volt one you mentioned in the 1st post is 24 vac, it would likely work just fine on 12VDC
