Those cooper lines are avalible new by foot (by meter in my country), just be sure to order the soft kind, not straight pipes which actually tough to bend. Also be sure checking the size since there's a trick with actual cooper pipe size and how it's marked in the sales lists. For fittings you can look Parker Fitting which would cover any need on whatever you break in the gas line. Vlad
PB blaster is great stuff!
I have question about the fuel system. Gas is not getting to the carb, with a little gas poured into the carb she starts and runs for  5 sec or so. I have disconnected the fuel line below the carb and no gas comes out of the line. I have added gas to the carb 4 or 5 times, she starts and runs but no gas come through the line. I have cleared the gas line from the pump to the tank. Truck hasn't been started in 10 years, so how long should it take for the gas to reach the carb from the tank? Any other advice would be helpful too.
Thanks
First make sure there is fuel to the pump. Then check the fuel pump actuating arm, it could be stuck from rust.  When the pump is off pump the arm and see if there is vacuum and pressure at the ports. There could be a problem at the check valves in the pump.
