Had a friend call Saturday in need of help. I was not able to help at 5he time but did get pics of the aftermath. Story goes he was using a friends 5 ton am general when the throttle stuck in reverse.  He panicked and threw it into drive. The transfer case must have been the week point. The owner told my friend he is to find parts to fix it. Owner was not happy
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/
The nation is full of army surplus truck dealers, all of which should have new, military rebuilt, or certainly good used.
Is it an M900 A1 or A2 ?
http://www.memphisequipment.com/
http://www.idahomotorpool.com/
http://www.whiteowl.com/
https://www.easternsurplus.net/
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-416017
https://www.easternsurplus.net/PartDetails/2360/9M-142-T1138-Rockwell-Transfer-Case
They are in Philly. I bought my M917 and trailer from them. Square people to deal with and will work with you somewhat.  Got to use your oil pump.
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-416024
Yes it could have. He had just pulled the electrician out and was backing up toward the road when it stuck. He has found one in Ohio for 3k. Thanks for the leads.
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-416043
The real cause of most of the transfer case issues is the Allison MT654's ridiculously low gear ratio in reverse compounding the engine torque to the point of failure.
This is why you should never use reverse in low range on these trucks.
Why did the the throttle stick?
Did the operator pull the emergency shutoff?
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-416059
Wondering the same thing.
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-416064
He is a good guy but seems every time he gets near heavy equipment something happens. He runs crane for a living. Dont know why throttle stuck but he panicked cause he was headed across the highway.
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-416078
  • 2 years later...
Man, that actually looks pretty nasty, that is the least I can say. Did he solve it?! I have never had a similar issue however my dad has been in a similar situation, but I have no idea how he actually solved it. I remember that he was really stressed out as it was not his own truck, the company that he was working for owned that truck and it was a bigger problem. He actually tried to call me, but his phone number was blocked. After that I bought him a number from https://quackr.io/rent-sms-numbers as they are having the best ones and the most secure ones.
Edited by Solaire
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-474566
  • 4 years later...
Same kind of mess happened to a buddy of mine with an old M939. Throttle stuck, panic shift - blew the transfer case seal. Owner wanted him to cover the fix.
He needed to register on a couple of military surplus parts sites, but they all wanted phone verification. Didn’t want to use his work number, boss tracks everything.
 Code came through in under two minutes. Used it to set up accounts on two different forums.
Ended up finding a used transfer case in Ohio — same day.
Not much you can do about the panic move, but at least the parts hunt didn’t take weeks.
https://www.bigmacktrucks.com/topic/55636-frantic-phone-call/#findComment-581921
  • Recently Browsing   1 member
