Adding oil to 2-Strokes (no not a joke....serious question...!)
the d.o.t would have to prove it. alot of guys run atf up here as a lubricant in the fuel. gg2
It is my understanding that DOT will take a sample and have it analyzed (if they see "dark" fuel).
Ken
HOF City, PRR Country, and Charter member of the "Mack Pack"
I was told straight 40w and when I called NAPA to get some since no other parts store had straight 40 Rotela the parts guy said "what do you have, a Detroit"? - pretty funny.
Just an FYI- you can usually get straight 40W in one gallon bottle cases (three per case) cheaper through oil distributors that sell retail from their warehouses. Also sometimes I get mine from Penn Detroit Diesel/Allison in Philly so if you have a DD/A shop near you check there too.
Agreed.... Never use 15W40.. even if there is a label on the engine saying so...
Detroit rescinded the bulletin approving it (I have it somewhere at work).... went back to straight 40 or 30 depending on ambient temp, and it must be CF-2 low ash...
however....... and there is always one of these..... I have spoken to operators of coaches, 8V92's, who still use 15W40 as it is easier and cheaper to buy in bulk, but they realise the oil breaks down quicker and therefore have halved the mileage between oil changes.
your mileage may vary..!!!
BC Mack
owner of three green leakers..!!!
JT
found the reference..
http://brandon314.files.wordpress.com/2012/05/detroitdiesel_lube-oil-fuel-requirements.pdf
section 3.2... high temp shear, IIRC, the 15w40 was taking out pistons in the ring area...
Chevron have a Delo100.... Walmart up here in Canuck land have a 30wt, but we do live in igloos..right? mine's melting right now.. :twothumbsup:
BC Mack
Why put oil in a Detroit? Its just gonna leak back out!
Oh and I use power service or Lucas fuel additive in my diesels every other fill up.
