My MH project
No its not a Magnum, but it does have the E9 in it.
As for the light bar clearance issue. I cut the square tubing and notched it up into the frame. It sits no further back than the frame rail itself. I did move the 5th wheel anyway cause of the fenders. I put a 5th wheel slide all the way to the back of the frame to help get under trailers and to clear the fenders too. Ive put alot of thought in it all and hope it works as planned.
Frames do soak up a lot of paint, more if you use black epoxy primer, and cover it with a lighter colour, like red. Thats what I did on my Superliner frame, it ate up a good 3 gallons. Your MH looks real good, makes me miss mine.
