Field Marshall Starting Cartridges
BAD DOG
:SMOKIE-RT: A friend of mine's dad has a British Field Marshall Diesel that starts with a shotgun shell. He's been loading his own and getting by but he's looking for a north american supplier to get the proper starting cartridges. He said he can get them from England but they won't ship them over here. If anyone might know wher e he could get them over here he would really apprieciate it.
They are for whats called a Kaufmann Starter, seriously try a Aircraft supply house or surplus store ....or Rob may know? Paul
Never heard of that before. How does it work? Trey
They are a heat expansion/reaction starter. When the shell explodes with a slow burning powder the rapid heat expansion and buildup in the burn chamber causes a gear to engage the ring geat to turn the engine over. This is of course on a reciprocating piston engine. A jet does not have the gear but rather a set of "vanes" the expanding gasses bear against to cause rotation.
I really don't know where you would acquire such an animal as most of these things were either replaced with electric conversions, or use ground support equipment to furnish the starting source.
Az eye recall the diesel engine twaz a horizontal single cylinder
the operator turned the flywheel to just past TDC
a copper plug @ top of cylinder head twaz heated by useing a blow torch th@ normally twaz used to strip paint off the outside of house
or a modern propane gas heater, after bout 5 minutes of heatin the copper plug a shotgun type cartridgr with out shot twaz loaded into
cartridge holder n locked down then a hammer twaz used to hit the center bolt th@ hit the detinator in said cartridge
Where by the force sent the piston on its way, and the old beast came to life @ a speed U could count each firing of the diesel fuel
LOL
T H E R E Clear az mud
cya
§wishy
