Curious if anyone has gone through the paces of repairing a R model dashboard, Its the original Dash out of a 1973 R600 That my schools restoring. Its got a few chunks missing out of it and has padding showing in a few spots, Wondering if anyone has ever recovered one of the padded dashes and if it works well or not before we go through the motions of doing it. Any inputs appreciated.
https://www.bigmacktrucks.com/topic/75793-r-model-dashboard-repair/
5 hours ago, mrsmackpaul said:
It has a padded dash ?
I have never seen a padded dash in R model
A few different people make new dashes, but if your not in Australia they  will be of no use to you as they are RHD
Paul
Its got plastic bits on it, However a good majority of it is some kind of plastic/vinyl with foam padding underneath. Keep in mind this truck was from late 73 when they first came out with the bigger cab and the newer dashboard opposed to the steel dash.
2 hours ago, mowerman said:
I think he means the regular plastic what does anybody do with it after it cracks? I have heard of guys wrapping new material over the foam with a heat gun and glue. As far as anybody knows Dash parts are obsolete.. bob
Yep they are all obsolete, This truck is from late 73', probably some of the first trucks off the line with the then new style dashboard apposed to the steel dash. its the plastic/ vinyl material with foam underneath, its not so much that its cracked and theres a few spots of the material being gone and foam exposed. thats what i was curious about is if anyone has ever recovered them before.
  • Thanks 1
There were two kinds of those dash panels along the years. One style was plastic base with foam and vinil lamination, as described. The other one and the later one was solid plastic parts. ABS or so material. They were painted beige and gray metallic after a certain year. Those foam parts and solid parts seem interchangeable. And solid ones are much more steady and easy to fix (glue-fill-paint). I doubt there's a good way to fix foam conteining dash parts into or close to their original shape. There are laminating films with surface similar to automotive dash material (to repair or maybe even fabricate dashes?). But you doubtly could build up a layer of foam even enough to laminate it or glue up with anything. So on my mind two possible ways of fixing exist. Finding good used later style solid plastic parts and paint them over. Or bringing any style parts into upholstery shop to be furnished with leather or kunst leather.
I personally took that second route. And those my dash parts are taking place at a upholstery guy for 4 or 5 years now. Along with a roll of covering material.
Vlad
