1 hour ago, Freightrain said:
Maybe a truck pull front weight box???  You know, with the rollers on it????🤔
Sounds legit. I'm not an engineer but I don't see why that wouldn't work. I have an old lawn mower out back that you can the wheels off of if you want them.
https://www.bigmacktrucks.com/topic/75464-suspension-issues/#findComment-574726
2 hours ago, Joseph Cummings said:
It's supposed to be in a garage like 10 miles from me
l remember seeing him at New England Dragway in Epping NH a long time ago.
When we pulled garden tractors we always loaded up the beak to keep the nose on the ground. That way you maintained the 12" hitch height to pull down on the drive tires. The trick was as to how much weight you hung out out there to get it to float the front axle just off the ground.
https://www.bigmacktrucks.com/topic/75464-suspension-issues/#findComment-574744
On 4/28/2025 at 1:56 PM, Joseph Cummings said:
Reminds me of this a bit
I've seen that 20+ yrs ago at local track.  Likely a newer version driven by Bill.
https://www.bigmacktrucks.com/topic/75464-suspension-issues/#findComment-574839
