7 hours ago, BOBWhite said:
The only proper place for a Volvo is behind a Mack!
Not to derail but I've read that E-Techs get hot if the cam keyways wrong but I don't understand why.
I believe the E-Tech cam gear can have three possible positions based on the key used.
Pre CCRS:
Low HP 275, 300, 310/330 offset left. Red color key
Mid HP 350, 355/380, 400 straight key no color
High HP 427, 460 offset right. White color key.
CCRS engines uses the same cam gear key on all HP
Just a couple of deg timing can help with the overheating.
Corrections welcome.
