Air compressor bolts
Rybisp
2003 RD 688 with Mack E7 motor. Air compressor bolts backed out started pouring engine oil, torqued them back down a few weeks later same thing. Replaced bolts and used locktite on them. Now breaks the head off the bolt. Anyone ever have this problem?  If so what was your remedy that solved the issue? Thanks!
1 hour ago, Vmac3 said:
I think you would. It was a shot in the dark. Maybe a bad vibration damper.
V
we have seen the shafts break another long shot ! This shaft may have a crack and still driving! also the drive coupling could be worn!
