Tire/ Wheel interchange
My Hyster lowboy trailer has 10.00 x 15 LPT tube tires on Dayton spoke wheels that are ready for a changeout.
I' m looking for a chart showing size and compatibility to change to tubeless tires on Dayton wheels.
Looks like 11R 17.5 would be a direct swap for the tires but one of the questions is would a 215 75 R 17.5 wheel work with that size tire.
I’m trying to do the same thing local tire guy says no interchange for tubeless cause the sidewalls are so tall.  Was told need to change wheel hubs to go to tubeless   I’ve been doing research and it looks like he is correct   Tubeless tire are much lower profile and less weight ratings at that size
Edited by mrgumby
On trucks we changed from 1000Rx20 tubed to 11Rx22.5 tubeless  = exactly same diameter
on floats we changed from 8.25Rx15 tubed to 9.5Rx17.5 tubless = exactly same diameter
No need to swap dayton spider spoke hubs
all interchangeable and U can pare up tubless with tubed
the following info is not an indorsment but good info
cya
I know all about the tubeless  and tube swaps have done many of them but  the tires on my low bed aren’t just a normal 15 in they have very tall sidewalls every tire guy I’ve talked to 4  in all said the same thing   The 36 inch height 15 inch tire doesn’t swap to a 17.5 tubeless height wise I need the 36 inch height or a little more so the low bed stays off the ground so it doesn’t belly out.  Now they all run 22.5 low profiles for that height
I guess that I can deal with either a 10R x 17.5 or an 11R x 17.5 tire diameter.
My question is will they fit on any 17.5 wheel or will there be a difference in wheel width as the outside diameter gets larger.
The 215 x 17.5 wheels I am looking at are much smaller in diameter but I can't tell if the wheel itself is narrower in width.
  • 1 month later...
Got any pics of that Hyster?
