Sounds like the diaphragm is crook
If it holds bleed and works Im guessing that is all it is and vacuum is sucking fluid past a seal as it will be working the opposite way it is designed to under vacuum
Diaphragms I would expect should be easily available as they are in Australia
Looks like a fantastic ride
Paul
