advice
mowerman
as most of you know....i put up a steel building recently,,,,when there is snow on the roof,,,and the sun is shining,im getting condensation inside the roof panels,,,,does anyone else have this issue,,,and have any suggestions.....thanks bob
As a building inspector I get to see a lot of projects. And whenever anyone asks me for advice, I always tell them two things-
1. In-Slab hot water radiant heat. Install a (very) small gas-fired boiler and get a HUGE amount of heat. (and remember, heat rises....)
2. Spray-Foam insulation. More costly initial investment but the return over the years is well worth it.
