end707 front balancer
1975 end707 . diesel and no I don't wanna hear 707 is a gas job. been runnin this engine in my B since 2007, no issues.  on the way to Macktoberfest I blew both belts(some of you know) ended up getting a belt back on but after driving home I notice the balancer is wobbling. never noticed this before. are all balancers the same? like 673 711, 237 300? or do I need specific? and should I look further?? is this thing on its way out? bearings?? and again is a end707. its a 711 with maxidyne head gaskets and fire rings. I dunno what the specific purpose of this engine was but I can tell you it likes to run 1100-1800 and hates anything over that
gotta tear into it sunday. if you look at it, you can see a wobble like 1/2 inch like something is loose.  never thought about thrust washers. this has always been a tight  motor.only way thrust washers usually come loose is if someone slams a pilot shaft in hard while putting a tranny in. I have had a few 673's that I found the thrust washers in the bottom of the pan. put new ones in and it still ran like a top. this one has be a little puzzled. never paid attention til both belts came off. now that they are back on I stare at the balancer and see the wobble.
no weird noises or shaked other than normal, I have never seen a  B61 that didn't shake and rattle. this motor was done in the late 80's and used very little in a dump truck. it sat. I put it in my B in early 2000's . it was always a stout motor ad very clean and tight. other than a head gasket I haven't done anything to it.  I did pry against the balancer a little while putting the belt on(some idiot when they built the truck, me forgot to put the spacer plates back in radiator crossmember so there was no room for the belt. I had to loosen crossmember up and pryed it out against the balancer to get belt it. im wondering if I could have bent the balancer?? the hub in the middle of the balancer is pretty think so im thinking not. I have a few711's laying around, thinkin of just swapping the balancer and see what it looks like. btw a balancer for a 711 is NLA from Mack.
You mean NLA like 99% of parts for these old trucks? The part numbers I give them for my truck don't even show up on the Mack parts system any more.
