2001 mack e7 400 missing and backfiring
ou812jk
2001 E7 400 was running fine started to miss and backfire like jake stuck on remove wires to jakes still does it backed off on jake adjustment still missing removed external oil lines evened removed solenoids still missing
  • 2 years later...
I’m having the same issue with my 2006 aset engine. It idles fine but when I rev it up to 1200 or more it starts to miss and backfire. It smokes like a freight train and smells like kerosene. How can you tell which injector is bad? I tried breaking the fuel lines while it was running and I notice they all made the truck idle rough.  Do you have to remove each one and will you be able to visual see if it is damaged? Or could it be something else. Please help.
