Changing up my transmision in my 1988 R 690S
Casper1988
13 speed mack tranny od is .71    low is 13.91       your 2070 tranny is od .60   low is 14.16       the 2070 will run faster and have a slight lower low gear      my 2080 had a low of 20.08 and od of .60      with 5.73  gears I could start out loaded on a 60 degree incline and not burn the clutch       not a good tranny for the road thou in my opinion
After about third gear you need a splitter with the six,seven and eight speed trans in this series.    terry:D
I put the information about the Tranny on the BigMackTrucks.com facebook page.  You may reference the photo there under the visitors section in the right hand column. Unfortunately I was unable to attach any photos to this forum or gallery.  Input on how to correct the issue is appreciated.
Thank you,
Luke
Went to the shop yesterday to get oil, this is a well known shop in my area and talked to a Mack guy who has 30 plus years experience. really confused now, he said the 12 speed is big long and expensive to fix if there are issues with it . So he thought a 9 speed would be a good match up. Everyone does have a opinion on whats best for a swap out, still gathereing info and next will be to find some trucks locally and see what there running. I did take it for a ride yesterday after oil in the rears and king pin job, went real nice.
Luke, a conventional diesel engine produces peak power at 2100 rpm and maybe 90% of peak power at 1600 or so rpm, so a 9 or more speed transmission is needed. A maxitorque produces peak power at 1700, and at least 90% of peak power from 1200 to 2100, thus as little as 5 speeds are needed.
I have some time driving and shifting many different types of eqiupment around the farm (20 plus years ). I would say this 2070 is not the most easiest transmission to dial in but I am also in no hurry to get anywhere loaded. Once I drop the load though that .60 overdrive will get me home quick. Good advice on this site. Thanks all.
