B 61 Oil filter
The small one that truck repair provided was the second one they ordered, I might take it back and see if they want to try the third time. I was planning on taking it to the western Illinois Threshers next Thusday, friday and Sunday and time is running short.
The picture shows a full flow/bypass filter- Mack #236GB311A which as stated above crosses to a Baldwin #P706M.
It is not interchangeable with a 750 Luberfiner.
A 750 Luberfiner does not have gaskets on the top and bottom of it and and a Mack full flow/bypass does
Ron
I found a Baldwin P 706 M at T.H.E. Company in Mt Pleasant Iowa, about 30 miles from home. They had eight of them in stock. No local companies had anything in stock and would had to order. Its already installed and as soon as the weather cools off I will fire it up to check for leaks, this evening probably. Will drive the B to Hamilton IL for display this Friday thru Sunday. Thanks all for the very good information. Victor
