Interesting DM 6 series
Saw this DM for sale about a mile from my yard.Paint and body done by 40 grit, Rustoleum and a cheap brush. No info ,not even a phone number..Name and number on door is disconnected too..at a closed down factory. What was really interesting was the system to pressurize the tank I assume.....Paul
Can't see what the pressure system looks like.
Alot of times, they would have a deoderant spray to cut down on obnoxious odors.
Also could be to put a lite spray of diesel into box so debris doesn't freeze in winter
I have had to do the same thing to get a junk truck home with a bad lift pump. It was on a old S-series IHC 1900. We ran a air line from the bleeder on a air tank into the fuel tank through the fill hole and clamped a bunch of rags around it to halfway seal it. We opened a petcock in the line so it kept air pressure in the tank to force diesel up to the pump. It got us home, but we had to keep stopping to let the air build up in the leaky ol' binder.
It has the roll off set up on it the tank is on the pass side A phone number and a 8250.00 price on it. The fuel tank set up is hooked to the air tank.... You get up to the cab the door bottoms,roof edges and cab corners are metal tape. For those from the Island it was an old Jamacia Ash than Gershaws truck. Paul
