bulldogboy
Pedigreed Bulldog
Everything posted by bulldogboy
  1. cstaples: I was wondering what fire department that "RD-800" came from. Thanks for the info. Francestown Fire Department runs a 1995 Mack "RD"/EJ Murphy 1000/2500 tanker. There is a picture on www.firenews.org, Department List, New Hampshire, Francestown. bulldogboy
  2. I was basing the transmission selection on the "L" and "B" models that I operated: the "L" models pumped in 4th gear and the "B" models pumped in 5th gear. In all cases it was the highest gear for those engines. FWD is correct, make sure that you know the proper sequence for your particular engine. You don't want to have a scare like Joe in Yocum Creek, KY. had with his "CF". I operated these engines 40 years ago so some of the details may have been lost in the haze but I think I'm pretty accurate on how our particular engines worked. Oh well, off to the Bruce Springsteen and the "E" Street Band concert. bulldogboy
  3. Yes, that's about right on the top speed. These things are not speed demons; they were built prior to the Interstate highway system and were intended for responses around town plus the motors of that era were not as powerful as they are today. A sunny day, driving a semi-cab Mack fire engine down the highway; doesn't get much better than that. You will get lots of looks from passing motorists (plus a few curse words because you are only doing 45 MPH). Hope that the seller gave you good advice on the truck's ability to make it home. Good luck with this truck. One other thing about the pump set-up, before I get in trouble with the safety guys, don't forget to chock the wheels. We never did this in the "L" and "B" model days but today if you forget the chocks, look out. bulldogboy
  4. Most "L" models have an outside lever on the pump panel with three settings: "Road", "Prime", and "Pump". The procedure is to set the parking brake, put the transmission in neutral, then exit the cab and put the lever into prime or pump, depending on what you need to do, then put the transmission into the highest gear (usually fourth). You should hear the engine speed up and the speedometer and tach move. Now, having said that, it looks like in your picture the truck may have a lever inside to the left of the driver's seat (the photo is dark but it looks like a lever next to the seat). In that case, set the brake, transmission in neutral, then lift the lever (there should be a lock to hold it in place), then shift the transmission into the highest gear. Most "B" models and I'm assuming later "L" models have this interior lever. There will be a primer button on the pump panel. Be sure NOT to run the pump in a dry condition for long because you will do serious damage to the pump. If you can, put water in the tank, then prime the pump before you start to flow water. Been a long time for me since I operated "L" and "B" model pumpers. bulldogboy
  5. Could you get a few people together and pool resources? I know that retired firefighters' associations or relief associations will buy a retired department truck and use it for parades, funerals, P.R., etc. While you as an individual may not have full ownership of it, you will be preserving a piece of your department's history. There are many departments that have sold off old apparatus and then years later wished that they had that apparatus back. Good luck trying to preserve this engine. bulldogboy
  6. My town's P.W.D. has "Terrapro LE"s with steering wheels on both sides so we're covered no matter what. Any Mack fire apparatus still in service "down under"? bulldogboy
  7. Looks like a "B" model deluxe cab fire engine behind the 1963 "B-61". Anyone know where that is from? Thanks. bulldogboy
  8. Hey, everyone: Take and post lots of pictures of the Brockway fire apparatus in attendance. Thanks. I would love to be there. bulldogboy
  9. I didn't think that the specs I saw on Amherst Engine 4 sounded right; the truck is too small for 2000 gallons. There is a picture of it on www.firenews.org Department List, NH, Amherst. Amherst and Lyndeborough designed them to be source pumpers. Lyndeborough is very rural with no public water supply and Amherst still has areas of no public water supply. I'm from New England so I know a little (very little) about some departments. bulldogboy
  10. Former Amherst, NH Engine 4 - 1977 IHC/Gilbert Welding (Manchester, NH) 500/2000. Lyndeborough, NH had one similar to Amherst's. Is that LS-85 from Kittery, ME? bulldogboy
  11. Joe: That's good news; those old Macks are pretty tough and keep on truckin'. Hate to think how this would have played out with one of the newer electronic rigs. By the way, how did you make out with the brakes on the '67 Ford? bulldogboy
  12. Saw my first "CAT" truck today; it wasn't yellow. At first, I thought it was a Volvo on steroids. bulldogboy
  13. Since most of the Macks I drove were fire trucks I have to say red. bulldogboy
  14. dek1581: I'm not sure how many bolts there are. I drove a "C" model ladder truck many years ago and I remember the department mechanics told me that the canopy had to be removed to change the engine. I haven't seen a "C" model upclose in years so I can't help with the bolt issue. The canopy didn't seem all that heavy duty so I would imagine that once it was unbolted a few strong people could lift it off. Hopefully, someone with more mechanical knowledge of "C" models could weight in on the subject. Good luck with your project; "C" models were great trucks. bulldogboy
  15. An open cab "Granite"!!!! Wow, that would be awesome although a bit chilly in the winter here in New Hampshire. bulldogboy
  16. slpwlker: I have not seen the Seminole Mack tankers in person, only in pictures. They may be in the Clewiston/Brighton, FL area. bulldogboy
  17. Swab Wagon Company from Elizabethville, PA built a 3000 gallon pumper/tanker on a "Granite" chassis for Tylersport, PA in 2009. You can see a picture of it on the Tylersport website: http://tylersportfireco.com/apparatus.html#Tanker72. bulldogboy
  18. dek1581: The Mack "C" cab does not tilt. In order to remove the engine the canopy over the jumpseat area can be unbolted and removed. bulldogboy
  19. joes mack: Another manufacturer who will build on a Mack chassis is 4 Guys from Meyersdale, PA. The Seminole Indian Nation in Florida has two Mack "Granite"/Pierce 6X6 pumper/tankers. Some manufacturers will buy lots of chassis' to have on hand when orders come in; naturally, they will push to sell these chassis because they have money tied up on the purchase and need to recoup it. A Mack chassis will not be the cheapest that's why most departments go with IHC or Kenworth but if you can afford it I say go for it. Like Terry T says, an automatic for fire apparatus is better due to fewer and fewer people being able to drive a standard. In a volunteer department you never know who will show up and you hope that someone can drive the rig to the scene. I've seen trucks that could not respond because the guys who responded to the station could not drive a standard. Good luck with your new truck; it must be exciting for your department. Hope that you keep the "CF". bulldogboy
  20. I wondered why the military spec'd a Chysler engine in a Mack truck. If they wanted a engine similar to their other industrial engines did they also spec Chysler engines in all their other administrative vehicles in order to maintain commonality? I've never heard that the "B450CF" and "B475CF" models were built on Dodge chassis. I know that during WWII Mack mounted fire bodies on Chevrolet and Brockway chassis but during wartime trucks had to be rushed into service and everyone built similar vehicles. Seems strange that Mack would mount their own cab and body on another manufacturer's chassis. The U.S. Navy had a Mack stationed at the Chelsea Naval Hospital in Massachusetts. bulldogboy
  21. How long after the Bighorn was introduced did Dodge exit the heavy and medium truck market? bulldogboy
  22. According to the Upper Saucon VFD website they had a 1958 Mack "B" model 750/500. It was sold to the North Plainfield (PA ??) Exempt Fireman's museum. It will be on display and also used as a hearse for firefighters' funerals. bulldogboy
  23. Not only an "R" model tanker but also a big Autocar (Volvo !!!!) at the scene. If you like old in service fire equipment come to northern New England. While many small departments are now buying custom apparatus there are still lots of trucks more than 20 years old still in service. bulldogboy
  24. That's a terrible story. Hopefully, other departments pitch in and help get them back on their feet soon. It's always a shame when a fire station burns down due to a lack of an alarm system or sprinklers. Those should not be luxury items but with many departments short on cash they often get left out. Of course, in this case all the alarm systems and sprinkler systems in the world wouldn't have helped. bulldogboy
  25. Bruce Springsteen and the E Street Band!! Clarence Clemons, the greatest sax player ever, R.I.P. bulldogboy P.S. other dog Talking Heads were right up there on my list.
