Johnragno Posted May 15 Share Posted May 15 Is there any way to get more belly room in my new to me 1964 B 64 do modern air ride seats give more room from the original bench seats Quote Link to comment Share on other sites More sharing options...
theakerstwo Posted May 15 Share Posted May 15 I was around B models when they were ever were.It was common to see a heathy driver with his shirt or jacket worn badly in from around his belly were the steering wheel rubed.If it has power steering or air assist on it a smaller steering wheel may be the way to go. 1 Quote glenn akers Link to comment Share on other sites More sharing options...
Popular Post mattb73lt Posted May 15 Popular Post Share Posted May 15 From what I've seen and done, the seat backs need to be thin and low height for the bottoms. Low back seats are or seem to fit best. The standard B cab is pretty small and we're not getting thinner. Space is an issue. I've tried a couple of different arrangements . What I've settled on are spring ride bases and a pair of excavator seats, with arm rests, I sourced both from Northern Equipment. They fit the cab nicely and make me fit it more comfortably. I recently added a center console between the seats(not in the pics, though.). By the way, I do have power steering and have a 20" wheel versus the stock 22". 2 1 Quote Link to comment Share on other sites More sharing options...
Popular Post HarryS Posted May 15 Popular Post Share Posted May 15 I had the same problem replacing the fixed seat. Nothing seems to give much room. I ended up with a vintage Viking. After looking at Matt's interior it looks like the smaller steering wheel gives a little more relief. Those seats look awesome. 3 Quote Link to comment Share on other sites More sharing options...
mowerman Posted May 15 Share Posted May 15 Yes I know this is probably Not what you want but you might have to go to a custom smaller wheel There generally a lot easier to fine and some nice looking stuff out there but those smaller seats might do the trick good luck.. bob 1 Quote Link to comment Share on other sites More sharing options...
Popular Post mattb73lt Posted May 15 Popular Post Share Posted May 15 I had a Bostrom seat identical to Harry’s first, but it was worn out. Then a pair of ‘95 Mustang bucket seats some one gave me mounted to the same spring bases. Those really didn’t fit well and the high backs with headrests took up more room. I built frames for the bases to use the original bolt holes and another frame to mount the seat. The 20” wheel makes a big difference in room. I have a large Sheppard box out of a B61SX in it. Which makes it steer like a car. Here’s some comparisons of the two wheels and the bases in the cab. 5 Quote Link to comment Share on other sites More sharing options...
Mean Green Posted Saturday at 02:55 AM Share Posted Saturday at 02:55 AM Making my own seats right now using an air ride base with a volkswagen seat cobbled to it Quote If your going to be a bear be a grizzly Link to comment Share on other sites More sharing options...
