Having problems getting my spring brake cans aired up on my mid seventies R. I was going to put the bolt in and lock them so I could move it over to my shop (100 ft)...those bolts are missing on both cans! They're usually in that little holder on the can itself right?
Anyways I've seen these things plenty of times, but I can't quite picture them enough to make them.  How bout all thread with a pin welded across the top? Or is there a place I can buy them cheap and quick?
Thanks for any advice.
Martin
1965 Mack B-74, dump
1974 Mack R, logging w/Prentice self-loader
www.somewhereonthemountain.blogspot.com
Marty
Grab the shop air n fill the truck tanks n release brake n block truck so it dun roll over U n undo the slak adjusters so when all air is released the spring brake will be on but the slak adjuster wont let the linings tuch the drum = brakers R off
cya
§wishy
Thanks for the suggestions guys. For some reason I have no air coming back to the spring brakes...and when I press in the treadle, the a huge gush of air coming out of the treadle valve. This girl ran ok when I parked her 6 years ago. I don't have the time right now to problem solve...just neede to move her. So that's why I'll just do the caging bolts quick. If you have any ideas about the bigger issue tho, I'm all ears.
thanks
martin
