There's basically two different heads for a 673.
18 stud or 20 stud.
18 stud heads have a single corner stud on the drivers side.
20 stud heads have double corner studs on the drivers side.
All 5/8" studs.
One other thing to watch out for, there were two different 18 stud heads.
One had all 9/16" studs, the later ones had sixteen 9/16" studs with two 3/4" corner studs in the corners on the drivers side.
I hope this helps, you should be able identify them without having to remove the valve covers.
Ron
When you called the good folks at Watt's Mack (1-888-304-6225), what did they say on availability ?
Mack Part-no. 553GB3266B - Cylinder head gasket applicable to EN707, END(T)673 and END711 with 20 stud cylinder heads
Mack Part-no. 3029-8213C - Cylinder head gasket applicable to EN707, END(T)673 and END711 with 18 stud cylinder heads
Mack Part-no. 3029-8213C (replaced 553GB3267C) - Cylinder head gasket applicable to EN707, END(T)673 and END711 with 18 stud cylinder heads
Doing a quick google search on 3029-8213C the prices range from $140 to $250 for a pair, some of them giving an option for 18 or 20 stud with or without fire rings for an e6. I know nothing about the e6 but from the pictures they appear to be the same as my 673 N/A gaskets.
I can assure you that the part number is correct as I described. Those descriptions mentioning E6 are wrong.
