Bigdogtrucker Posted May 14, 2016 Share Posted May 14, 2016 Serial is B67ST 11418 Quote Link to comment Share on other sites More sharing options...
j hancock Posted May 14, 2016 Share Posted May 14, 2016 Maybe double check the number, only 8,780 units were made. Built between 1957-1965. 1 Quote JimIt doesn't cost anything to pay attention. Link to comment Share on other sites More sharing options...
Bigdogtrucker Posted May 14, 2016 Author Share Posted May 14, 2016 Quote Link to comment Share on other sites More sharing options...
j hancock Posted May 14, 2016 Share Posted May 14, 2016 No need to double check..... I would say it is a late one! 1 Quote JimIt doesn't cost anything to pay attention. Link to comment Share on other sites More sharing options...
Bigdogtrucker Posted May 14, 2016 Author Share Posted May 14, 2016 Guy thinks it's a "59, I said no way. Has a 711 too... Quote Link to comment Share on other sites More sharing options...
j hancock Posted May 14, 2016 Share Posted May 14, 2016 Thinking the 711 came out around 1962. 1 Quote JimIt doesn't cost anything to pay attention. Link to comment Share on other sites More sharing options...
Maddog13407 Posted May 14, 2016 Share Posted May 14, 2016 pictures? 711 came out same year as the F model I think. tell tale signs are usually the crossmembers in the frame, the early ones had the two holes for air lines, later ones had the hole in the center and about 63-66 didn't have the indented weld joint on top of the crossmembers ., the R model style dome light instead of the twin porcelain ones , push button junk signal switch instead of column mount. sometimes hard to tell but most B models after 1960 had a gray painted diamond plate brake pedal instead of black also. and after 61 they went to the silve mack emblem with dog on top on the heater box instead of the black oval one. 2 Quote Link to comment Share on other sites More sharing options...
39 Baby Mack Posted May 14, 2016 Share Posted May 14, 2016 I'm just guessing, but I take it you didn't like the KD turn signal switch Matt??!! Ron Sent from my SM-G900V using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
hiwy50 Posted May 15, 2016 Share Posted May 15, 2016 Bigdog, My Mack, B67T10008 is titled as a 1964. Your dash picture shows a box with two switches to the left of the dash gauges, Mine has the remains of this box. What is it. Thanks Richard Quote Link to comment Share on other sites More sharing options...
j hancock Posted May 15, 2016 Share Posted May 15, 2016 The box is the turn signal switch. Quote JimIt doesn't cost anything to pay attention. Link to comment Share on other sites More sharing options...
Maddog13407 Posted May 15, 2016 Share Posted May 15, 2016 that's the POS box. yup. hate those things Ron Quote Link to comment Share on other sites More sharing options...
hiwy50 Posted May 15, 2016 Share Posted May 15, 2016 I would like to replace the broken one on my dash. Does anyone have one for sale. Richard Quote Link to comment Share on other sites More sharing options...
39 Baby Mack Posted May 15, 2016 Share Posted May 15, 2016 There are a couple of new ones on Ebay right now. Ron Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
