mack trans 1958 b 61
I have b61 mack  that need a little more top end it has end 673 and a 10 speed  I have lived with it quite while but the starter ring has lost a few teeth so I got to pull the trans good time to make change does know what would help it I don't pull heavy load just antique tractor and car to shows thank junkman
Another box will take some frame length.  What is the wheelbase now?  What model 10 spd?  TRDxxx?  Is it overdrive?
What is your current ratio out back?  5.xx?  Need to get it into the 4's.    An OD trans with 4.62 rear will get you 65 mph on the floor.
Edited by Freightrain
1 hour ago, hicrop10 said:
My B87 has a 5 speed with an aux.trans and 9.10 ratio and I top at at 72.Now my mpg was around 4-5 empty and about 2-3 loaded.
I would like to see what you have for a tranmission! A double overdrive with 9.10 rears might run 50
Edited by terry
