R Plus Cab Questions
I am sure this info is somewhere on this site but too lazy to search....
First year for the R Plus cab?
Is there a noticeable difference in leg room in the Plus cab?
First year for the "plastic" dash in a R?
Is the Plus cab a "direct" bolt up on an earlier R (mounts, steering, electrical, air, etc.)?
Other improvements in the Plus cab versus earlier cab?
Thanks for the info!
Ken
HOF City, PRR Country, and Charter member of the "Mack Pack"
hmm lets see....
1-dunno
2-yep
3-dunno
4-dunno
5-other than the extra room, um......it has a kinda curved back wall? maybe? not really anything else I can think of.
oh wait yeah theres one more thing, it has longer grab handles!
73 or so give or take a few months was the first year for the plastic dash. yes little more leg room because the seat goes back a little farther, BUT not far enough haha. and direct bolt up? not so much. need to change the front frame mounts, depends on steering and depends how the fuel tank/rear cab square tube is. I put a newer telescoping steering wheel and swing down clutch pedal with cable clutch in my 66 R model. was a pretty direct bolt up. holes were all there.
Thanks for the information. I thought the plus cab started around 1973 but was unsure of other specifics. So if I want a R, I should be looking for a 1973 or newer? To recab a "rusty" pre-73 would require an early cab? I am not into repairing sheet metal.
Ken
its possible to recab an older R with the newer style cab but you need the front cab mount brackets for the frame as the older cabs has the biscuit mounts like a B model and the newer ones had the saddle type mounts like a Superdog. also might have to change the rear cab/frame mount depending on what fuel tank set you you have. out r model at work has the square tanks mounted like a B model. most R models were under slung tanks that hung off the square tube that went across for the cab mount.
the galvanized cab was a Macungie thing in the early trucks, my 84 was a Hayward truck and had no galvanizing, they tend to rust quicker for sure.
our 84 R has a galvanized perfect rust free cab. That's the main reason we bought it.
Nice, I have been trying to pay attention since my 84 and most of the Hayward trucks that came east seem to be worse than the Macungie trucks.
