Found another H model in Colorado
I wondering if that tag was not factory built? I know of another H like that with the same type set up. You adjusted the arm to one of the two spots to adjust the amount of weight that was put on the tag. Bet it was a real bugger in the snow since you couldn't dump it off easliy.
I'm guessing a lowboy truck with the ramps going up to the fifth wheel plate area.
