Neway Air Ride
Yup, same sheet I have. When it came down to it I just leveled my panhard bar and called it good. Seems I couldn't get both side even, like the frame might have a slight twist in it(came from dump truck). Got two years on it, no problems.
I also removed one valve and just run one now. I had/have an issue with an air "leak" noise occasionally. Was told that maybe one of the valves was off enough to fight the other. Removed one rod and plumbed to just one valve. Still have that "air release" noise randomly. Won't do it just sitting still, only when traveling down the road.
When I first did the back, the bags would leak off in an hour due to the old valves.. Put new valves on it, and it will sit for months and not go down. I like it!
