stealth engine break
oilburner
Does anyone know what the diffence in a stealth break and a regular jake is, the 98 454 we have has a steath and it says on the dash for best proformance use at 1800 to 2100, it hardly makes a sound when jakeing and does not seem to hold very good, the 94 we use has a better jake, so what is the deal with the stealth i can't find any info on it.
So what do i need to do to change it over? can i use the jake heads or do i need to change them to
From The Mack EIS web page about Jacobs Extarder engine brakes:
"An E7 engine equipped with a Stealth™ Retarding System will have the following different, or additional, features:
  • Heavier inlet and exhaust valve springs
  • Heavier valve rotators
  • A different Jake slave piston setting
  • An Extarder unit
  • Air supply for Extarder control
  • Different electrical connections to provide for Extarder-only operation (with dash switch in LOW position), or Extarder plus Jake Brake on both heads (with dash switch in HIGH position)"
I would assume you could remove the stealth exhaust brake/gate and not have to change anything else, other than plug an air line and adapt the exhaust. You may want to change the jake adjustment from .100" to .080-.085", It might help a little.
  • An Extarder unit
Thanks everyone i will try it.
we have a 98 CL713 with a stealth brake and it works great. .as a matter of fact it broke once and the regular jake brake with out the stelth hooked up is awful. so we put a pacbrake exhaust brake on it. we had a 95 western star with a 425 cat and the 454 with the jake and stealth combo outperformed the cat jake. i guess alot of people didnt like them but we have had good luck we bought the truck brand new and like the stealth. my dad actually built a 07 CL glider kit with a vmac 2 427 and installed a exhaust brke on that as well. works great . we are in the process of installing a pacbrke exhaust brke on our superliner with a E9 500 as well.
I was looking at it today and the exhaust brake is missing on the truck, i guess someone has already taken it off. But to be honest i have never seen a mack that had much of a jake break, the strongest one i have drove was a old 350 2v with a dynatard and it wasn't much.
yeah that 98 should be alot better than a old e6 350 you might want to invest in a pacbrake . i know ours is awful without the stealth/pacbrke. i think they had the jake detuned on the trucks with the stealth setup. the E7s and etech jake brakes are not that bad alot better than a dynatard
right now it's not as good as a b model cat, and they did not have much of a jake, but i had it off road and in the lower gear it held ok but i feel like it could be better, i thougth only one head was working so i unhooked one, nope they were both working, and there is quit the delay before it kicks in and it wont jake under 1300 rpm, so i am thanking it is still the steath jake setup without the pacbrake, because the switch does not interfear withe the jake, low and high can not tell any deffernce.
the stealth brake was a Jacobs compression brake and an exhaust brake the exhaust brake was the stealth part making the exhaust quieter. I have removed the exhaust brake from a friends truck and changed the wiring to match a standard Jacobs E7 engine brake hi-lo-off,or two heads, one head, off the added strength of the valve springs is actually a good thing for the engine and wont hurt a thing. I have also replaced the factory oil pump with a high volume oil pump from...... PAI I think and the added oil flow made the brake work great it had to almost double the braking effort. I know the settings on the Jake on the stealth trucks was a little wider check the gap and set it to that of a standard E7 Jake and it will work a little better.
